Post 186585 by Loz1 on 2008-10-06 21:19:47
On a recent visit to me local volvo garage, i gave them my car for a quick once over to see if everything was running ok. Not being car mechanically minded (more motorbikes to a point), i was confronted with a "TO DO" list on things that were supposedly wrong with the car (hoses have been dealt with in another forum on this site). Now, for a car with a Full service history with loads of bills when bought (mainly Volvo main dealers), i was taken aback with a advisor that the rear crankshaft oil seal needs replacing as it is leaking. Now, i'm not mechnic (as said before), but i have had the car on ramps and had a look underneath, and i see no leaks, misting spray or anything else that would lead them to this conclusion, or i'm i missing something. Is there a spy window enabling them to see this seal (as i am being quoted close to £600 for them to do this. (Car only cost me £950). Don't get me wrong, i know things go wrong with performance car's, especially 12 year old ones and i don't mind paying for things that need doing, but this seems wrong. Any advice???
Post 186587 by Loz1 on 2008-10-06 21:21:50
The cars a 1996 Volvo 850 T5 CD estate it this helps with approx 94,000m on
Post 186591 by t5 pete on 2008-10-06 21:29:24
There should be a sign of a oil leak have a look on your timing and serpantine belt to see if theres any oil on them.
What condition is your car in because thats quite cheap for a cd spec and low milage
Post 186593 by readview on 2008-10-06 21:32:06
There is no access hole or window,rear seal failure is diagnosed by oil leaking from between the engine and gearbox mating faces at the bottom,underneath the car.If it has gone badly enough to be visible then i would expect you to have noticed the car needing topping up more regularly,unless it has only just started to weep.Turbo return pipes often leak at the o ring and can be mis-diagnosed when oil has spread everywhere.The repair price does seem steep,the part is not too expensive and labour should be about £250-£300.
Post 186599 by stainesy on 2008-10-06 21:36:46
i need to top my oil up every month with a 1 litre bottle but oil light has never come on and it only goes down abit. but i do have loads of oil on the bottom of my engine. but looks like old oil. could i have an oil leak?
sorry to piggyback your thread
Post 186607 by cameron on 2008-10-06 21:47:13
Sounds like the O ring on the turbo return pipe as Readview pointed out before, i to was going through oil like nobodys business and it was plastered all over the bottom of the engine.
Adam kindly pointed it out and i got the parts ordered.
£3.50 all in for the O ring and the top gasket off Rufe, 2 x 10mm bolts at the top of the pipe and 10 minutes to change the seals over, i done mine the other day. PM Rufe and he'll sort you out.
Post 186612 by Loz1 on 2008-10-06 21:57:46
[quote=t5 pete;186591]There should be a sign of a oil leak have a look on your timing and serpantine belt to see if theres any oil on them.
What condition is your car in because thats quite cheap for a cd spec and low milage[/quote]
Car is in really good nick. Was advertised when i bought it for £1150 but was able to knock him down because of the drivers side cv joint boot had split and sprayed the grease up the inside of the wheel arch (cv was fine, £12 for the cv boot). Previous owner had dogs so dog hair was everywhere. Just gave it a good valet and looks like new. A few minor scraps to the bumpers but mothing too bad.
Timing belt looks fine
Post 186613 by Loz1 on 2008-10-06 22:01:40
[quote=readview;186593]There is no access hole or window,rear seal failure is diagnosed by oil leaking from between the engine and gearbox mating faces at the bottom,underneath the car.If it has gone badly enough to be visible then i would expect you to have noticed the car needing topping up more regularly,unless it has only just started to weep.Turbo return pipes often leak at the o ring and can be mis-diagnosed when oil has spread everywhere.The repair price does seem steep,the part is not too expensive and labour should be about £250-£300.[/quote]
No oil to be seen anywhere. The underside of the car is basically spotless. Also, the oil level is fine, not needed to top it up. The gear changes are smooth
Post 186614 by Loz1 on 2008-10-06 22:02:19
[quote=stainesy;186599]i need to top my oil up every month with a 1 litre bottle but oil light has never come on and it only goes down abit. but i do have loads of oil on the bottom of my engine. but looks like old oil. could i have an oil leak?
sorry to piggyback your thread[/quote]
No worries
Post 186615 by cameron on 2008-10-06 22:05:25
Hi pete i had a 96 T5 CD with 7 seats, it was immaculate, i bought that for £800 @ it had only done 100k
piccy in this thread, http://www.vpcuk.org/forums/showthread.php?t=16856&page=2 post No 21
Post 186633 by readview on 2008-10-06 23:26:23
In that case it does sound like your garage is trying to create work(and expensive at that).If in doubt get a second opinion,if you are anywhere near us i'd be happy to check it out for you.(Accrington in Lancashire)
Regards,Adam.
[quote=Loz1;186613]No oil to be seen anywhere. The underside of the car is basically spotless. Also, the oil level is fine, not needed to top it up. The gear changes are smooth[/quote]
Post 186635 by readview on 2008-10-06 23:32:02
It sounds like you certainly have an oil leak,you could either have it diagnosed and repaired or simply tell folk you have a progressive oil change system in place as you dont want to burr the edges on the sump bolt.:)
Post 186636 by irf on 2008-10-06 23:53:27
start the car, pull the dipstick out. if you're getting smoke out you need the pcv doing. driving the car like this for an extended time is when i've heard that the seal goes.
how they know the seal going though is beyond me.
but if you dont get smoke out the dipstick, surely the rear main seal is okay?
Post 186638 by yellowt5r on 2008-10-07 00:01:48
what dont need seeing to on your car stainsy LOL
Post 186647 by PNuT on 2008-10-07 05:28:09
[quote=Loz1;186585]On a recent visit to me local volvo garage, i gave them my car for a quick once over to see if everything was running ok. Not being car mechanically minded (more motorbikes to a point), i was confronted with a "TO DO" list on things that were supposedly wrong with the car (hoses have been dealt with in another forum on this site). Now, for a car with a Full service history with loads of bills when bought (mainly Volvo main dealers), i was taken aback with a advisor that the rear crankshaft oil seal needs replacing as it is leaking. Now, i'm not mechnic (as said before), but i have had the car on ramps and had a look underneath, and i see no leaks, misting spray or anything else that would lead them to this conclusion, or i'm i missing something. Is there a spy window enabling them to see this seal (as i am being quoted close to £600 for them to do this. (Car only cost me £950). Don't get me wrong, i know things go wrong with performance car's, especially 12 year old ones and i don't mind paying for things that need doing, but this seems wrong. Any advice???[/quote]
im fairly sure there is a tiny hole between the gearbox & engine face too diagnose leaks, when my clutch slave cylinder went hydralic fluid came out of mine....
if you have no oil coming from there then it aint gunna be your rear seal....
Post 186680 by johntheace on 2008-10-07 10:53:13
best advice i could give is get a second opinion...good luck with it
Post 186681 by jez.w on 2008-10-07 11:21:21
I think pNUT is correct. I have a small slot on the bottom of the autobox casting where it mates to the engine block. The slot is just about big enough to get a small flat blade screw driver in. If this is gummed up, dripping or wet with oil then you probably have crankshaft oil seal problems. I was told this by a mechanic when i was looking at 850's as this is common-ish problem on higher mileage 850. I have read many times that if you change to fully synthetic oil when the seals have been exposed to semi synthetic oil you can finish off worn out seals.
Post 186757 by stainesy on 2008-10-07 16:42:35
[quote=yellowt5r;186638]what dont need seeing to on your car stainsy LOL[/quote]
yes but is it all just in my head or is it real? :crazy:
Post 186771 by jonno12 on 2008-10-07 17:08:38
most of its in ya head lol
Post 187022 by Alan M on 2008-10-08 10:31:31
[quote=stainesy;186757]yes but is it all just in my head or is it real? :crazy:[/quote]
Going by previous posts, its most definately real problems.
Post 187036 by hd9584 on 2008-10-08 11:34:21
When the rear seal leaks, it's at the gearbox end. Usually there will be a lot of oil between the gearbox and engine casing, if your one is dry then it's leaking from somewhere else.
