turbo gauges
Post 180466 by p0xy on 2008-09-06 17:29:03
can people post pics where they have the turbo gauges in the 850's please and what pod or whatever they have put them in... cheers :)
Post 180509 by stevenb on 2008-09-06 21:30:27
mine is on a pillar at bottom where it fits great and makes taking the vacuum pipe off the standard gauge for new one very simple. Goto www.autodials.co.uk they have a great selection of a pillar pods or dash top pods and if you wanted they do a triple gauge holder for a single din radio slot so you could take out standard radio replace with single din unit and fill gap with gauges. And they are cheap too. Will upload pics when i get 5 mins spare.
Post 180510 by stephenevans99 on 2008-09-06 21:42:11
I bought an AutoGauge ( pictured) originally but soon replaced it with a Smiths gauge...far more accurate and a lovely smooth action !!??!! Image Mounted in a pillar pod bought from partsforvolvosonline
Post 180518 by badger1980 on 2008-09-06 22:50:31
Im very tempted by the digital gauges any recommendation
Post 180547 by p0xy on 2008-09-07 11:41:21
so how easy are these to be put in?? also has the 850 t5 got a dunp valve as when turbo kicks in and i change gear i can hear the sound like a dump valve
Post 180551 by Alan M on 2008-09-07 11:57:53
The gauges are pretty easy jobs to do. Just take your electrical supply from the igniton switched live and the vac reference from the original gauge. A standard Td04hl turbo has a recirc valve fitted as standard to the side of the compressor housing on the turbo.
Post 181798 by p0xy on 2008-09-13 07:59:38
cheers mate :)
Post 181981 by Dan850T5 on 2008-09-14 15:40:45
[quote=p0xy;180547]so how easy are these to be put in?? also has the 850 t5 got a dunp valve as when turbo kicks in and i change gear i can hear the sound like a dump valve[/quote] Yeah they have a standard Re-circ valve which you can hear ever so slightly. If you were to fit an aftermarket blow off valve you need to blank the re-circ off with a plate that can be bought from partsforvolvos
