Post 175900 by Alv70t5 on 2008-08-15 11:46:32
I've finally nailed my ABS fault, it’s been showing "Brake failure stop safely ASAP" randomly for a few months, then it shows "STC service required". Spent my £80 at a dealer getting it fault found, they said it was all perfect? I striped out the entire fuse box, under the bonnet to get to the ABS plug, and found about 4-5 bad connections, repaired these and no fault for 2 months, but then low and behold it started showing again, very rare at first but then adamant toward the end. I must have just disturbed it. I bit the bullet and brought a replacement ABS/STC unit and fitted it. (you can fit this WITHOUT programing). Totally cured the ABS/STC fault and the other Cruise control fault, and it through up the engine management light for the throttle module (Had Volvo clean and update the software for this- FOR FREE)! cured. After looking at the old abs/stc unit there were 5-6 burnt pins that were no doubt arching and causing a power surge to the rest of the system, lucky it was just the abs/stc unit. So as you can see the new Phase II's been more than a bit of a pain in the as*! Nice to hear the turbo whistle nicely now, time to get it re-mapped and allow it to boost at 18psi again :)
