a simple question or 2
Post 164206 by vazman on 2008-07-07 11:59:51
i have a 1998 s70r and i was wondering 1, what size are the door and dash speakers? 2, how do the door cards come off/or other access to the speakers?
Post 164216 by Vikingxl on 2008-07-07 12:12:27
Door cards are a simple removel mate First remove the screw cover in the back of the interior door handle and undo the screw in there then push a small thin object between the metal of the door and the door card at the bottom edge.Gently prise the door card awat until you can get your fingers behind it.Now ease the card away and then when all the plastic push fittings have come away lift the card away from the top of the door frame,reach behind and disconnect the wires and you are away
Post 164219 by vazman on 2008-07-07 12:15:48
i havent really looked but i thought id ask before i started just so i wouldnt damage them
Post 164221 by Vikingxl on 2008-07-07 12:17:42
Pressed submit a bit quick so had to redo the post sorry if it looked a little odd
Post 164223 by vazman on 2008-07-07 12:21:51
cheers ill give it a got at the weekend
