Post 163485 by JOHN 850 on 2008-07-03 21:32:59
Have the above problem on my car - all the binnicle instruments have failed with the exception of the seatbelt warning light & yellow management light ? If I give it a bang a few times with my knuckle they usually come back on, so it looks something like a dry joint - has anyone else had this problem ?
Cheers,
John.
Post 163492 by Baj on 2008-07-03 21:51:16
I think the majority of the lights in a P2 are surface mount LEDs so it isnt a mass bulb fail.
I would start with checking the connector plug on the back. If it is circuit board based you will have a hell of a job I would have thought.
I wish you luck.
Post 163512 by Loadsamiles on 2008-07-03 22:26:16
It is indeed a dry joint. The issue was well documented on the VOC forums before they disapeared up their own A***
Post 163523 by Redbrick on 2008-07-03 23:07:26
Yup sounds like DIM failure.
Someone said they had got a replacement from here:
http://www.bba-reman.com/catalogue/DetailedProduct.aspx?DetailedProduct=1237
Someone else said they had had it re soldered.
As I understand it a second hand one from a scrappy won't work as they are coded to the original car.
My warranty covered the cost (thank God) and I ended up with the later version with the silver rings around the instruments.
Post 163532 by Loadsamiles on 2008-07-04 00:58:25
[QUOTE=Redbrick;163523]Yup sounds like DIM failure.
My warranty covered the cost (thank God) and I ended up with the later version with the silver rings around the instruments.[/QUOTE]
Spot on!
Post 163533 by Loadsamiles on 2008-07-04 01:02:14
HEY WOBBLY....
A new sideline for you!!!
Sod the ABS repairs they are so yesterday.
D.I.M Repairs... The way forwards.
Same script diferent module.
Post 163583 by TomS60 on 2008-07-04 12:47:21
I think the 2003 S60/V70's were bulbs. I thought only the MY05> and the R's were SMLED's.......but I could be wrong!!!
Post 164593 by JOHN 850 on 2008-07-07 22:11:12
Cheers for that guy's - will ring bba for a cost tomorrow. Have had it out & the connections are o.k. - if a s/h board won't work, not quite sure how a recon works, but I guess they'll tell me all !
Wonder if it is just one spot on the board that goes i.e. one part or anywhere ? Seems like it just effects 2002/3 D5 models though for some reason.
Cheers,
John.
Post 167220 by JOHN 850 on 2008-07-16 14:17:17
Just a quick thank you to everyone who replied - sent it down to BBA last thursday & go it back repaired via UPS yesterday lunch for £150 +VAT & carriage. Plugged in & all now fine ! Certainly better than the £780 from my local steeler for a new one & no, s/h ones won't work as all tied up with software issues.
Cheers again guy's,
John.
