Post 161206 by Ardchuig on 2006-11-12 23:20:44
A friend of mine has a '95 440 that will not start, garage say it's the immobiliser but say it's a complicated job and aren't too keen on doing anything with it. Anyone else had problems or would it be possible to rip it out or bypass it??
Post 161261 by thunderace on 2006-11-13 04:34:50
have you tried taking the fuse out, might not work but... :)
Post 163963 by fireclown on 2008-07-06 16:49:32
i managed to get round mine. but that was a diesel, afterwards the central locking did not work. i did manage to trawl the net and find some info on it. i will see i if can dig it out,
Post 168252 by readview on 2008-07-19 13:09:46
The immobiliser ecu is located just above the fusebox,clipped into a plastic holder.It is pale grey and about 5"x3".If you whip it out and aquire a replacement from a breakers complete with the matching fob it will plug and play no problem.I dont think we have any of these left but i will check on Monday and let you know.
Hope this helps,Adam.
