Post 158971 by Vikingxl on 2006-11-06 00:58:27
Thats a huge looking battery and an even bigger piccy and who nicked your strut brace?
the strut brace is a yellow OMP, and its sitting in my room waiting till I get my new suspension installed (this fri). I havnt put it on yet though.
Post 158982 by Vikingxl on 2006-11-06 01:06:30
Looking forward to the piccys already!
Post 159016 by iGGy on 2006-11-06 09:17:52
Nice install. I considered an Optima, but can't justify spending £150+ when I know I need things like the aircon servicing.
Post 159023 by Niles on 2006-11-06 10:04:27
daft question but waht difference would a supa dupa expensive battery make to the running?
Post 159027 by dreadly on 2006-11-06 10:16:36
[quote=Niles]daft question but waht difference would a supa dupa expensive battery make to the running?[/quote]
http://www.optimabattery.co.uk/english_optima/yellow_top_optima.htm
It's not the running it effects so much, but with a carPC - electrical supply with a constant voltage rather than a steep drop off would be important.
Post 159045 by Adge on 2006-11-06 13:25:34
Looks as though it's good enough to last long enough to be used in your wheelchair later on!!lol
Post 159066 by elliot on 2006-11-06 16:40:58
It looks like you have run out of coolant!
[QUOTE=elliot]It looks like you have run out of coolant![/QUOTE]
yeah, someone on volvospeed noticed that, its been fixed.
I didnt want to replace my batt with something that couldnt handle the carpc and I wanted to continue my theme. It wasnt too much more then a normal battery, $169 vs ~$60. I just wish it were a slightly less bright yellow.
Post 159115 by wootty on 2006-11-06 21:13:34
they are expensive but optimas do take a good drain especially if your running a couple of 1000w amps and 12" subs.most of the sound off guys i know use them.
