Hybrid Boost Controller
Post 154055 by SAMXPJ on 2006-10-20 13:55:58
Has anyone fitted a hybrid boost controller [mechanical] to a Rica'd 310 70series pre me7 as I was thinking about doing so but not sure if there will be much advantage.
Post 154079 by hamish on 2006-10-20 15:34:00
[QUOTE=SAMXPJ]Has anyone fitted a hybrid boost controller [mechanical] to a Rica'd 310 70series pre me7 as I was thinking about doing so but not sure if there will be much advantage.[/QUOTE] Sam, It might break your engine ! If you have any queries about our products or services it is always best to contact ourselves in the first instance. Regards, Hamish.
Post 154082 by SAMXPJ on 2006-10-20 15:53:57
Take your point Hamish, but just trying to make up the difference between what the ecu that Adam upgraded on my previous s70t5 ie my boost gauge showing max boost @17lbs and the max boost on my current s70t5 which is maxing out @ 15lbs. whether the gauge is accurate is irrelevant it's horses for courses. I'ved checked for leaks and can't find any. Sam.
Post 154086 by volvotuning on 2006-10-20 16:33:08
[QUOTE=SAMXPJ]Take your point Hamish, but just trying to make up the difference between what the ecu that Adam upgraded on my previous s70t5 ie my boost gauge showing max boost @17lbs and the max boost on my current s70t5 which is maxing out @ 15lbs. whether the gauge is accurate is irrelevant it's horses for courses. I'ved checked for leaks and can't find any. Sam.[/QUOTE] sent a pm. Adam.
