Post 154012 by ss003c on 2006-10-20 10:34:21
Hi all. I hope somebody can help me out here. I have a 96 t5 Estate which had a Premium sound stereo fitted. I have upgraded to a Kenwood KVTM700 whilst still using the same wiring and speakers... When I turn the stereo up and a bass note peaks it cuts out and the screen goes blank for a few seconds then comes back to life?? So far I have temporally upgraded the various fuses in the box to see if that helps,but to no avail... Also I saw in the Haynes wiring diagram that there is a power overload relay fitted somewhere,so I thought this may be causing the problem.So to overcome this I wire direct to the battery but still does the same... Im not 100% with the stereo wiring setup on my car and was wondering if anybody could tell me the run of the speaker cables etc from the stereo.. Strange thing is that when i disconnected the 8 wire iso speaker block,it cut out all the speakers apart from the 2 tweeters in the top dash.. Many Thanks in Advance.. Steve
