Post 12971 by gibbo on 2005-04-06 10:50:14
Just a quick thread to say a massive thanks to Dave for fitting the boost gauge last night.
Top Man
Top Job
The demo of your car around half of Brum was totally impressive.
Not sure what i was most impressed with:
The Power :jaw:
The Handling :jaw:
The Brakes. :jaw:
Probably all of it.
Again massive thanks mate.
Gibbo
Post 12973 by Bracer on 2005-04-06 10:55:41
Glad Dave gave you a good showing of all his goodies :hidesbehi
And enjoy your new toy :firedevil
Post 12975 by Mrsmopp on 2005-04-06 10:58:54
Another victim Dave!!! Are you going to leave us with any sane members :insane: or are you going to make sure they all get the "Dave experience?" :rice: LOL
Well done Dave - Top chap for T5's in need!
x
Post 12976 by Wobbly Dave on 2005-04-06 10:59:18
You are most welcome. I had a wicked time despite being a bit random with tools from time to time. We even managed to go and see my next car (S60R in Becklands Volvo - Black with 18s, mushroom interior - Ohh Yes)
There was that chav prat in his VW Polo. Obviously didn't see me coz his cap peak was over his eyes. He certainly picked on the wrong Volvo.
Later there was that Jeep Cherokee with aspirations of Speed! :cuckoo:
Anyway - I had a great time and was glad that the boost gauge went in OK - even if it took a bit longer than it should.
What boost levels were you getting from yours, Chris?
Post 12978 by steveT5 on 2005-04-06 11:02:40
I fitted my boost gauge a couple of months ago now. I wasn't sure wether i wanted it to be temporary or permanent. I have now decided to keep it. could you tell me how to connect it to the dash illumination?
Thanks,
Steve.
Post 12984 by gibbo on 2005-04-06 11:15:27
[QUOTE=dave850R]You are most welcome. I had a wicked time despite being a bit random with tools from time to time. We even managed to go and see my next car (S60R in Becklands Volvo - Black with 18s, mushroom interior - Ohh Yes)
What boost levels were you getting from yours, Chris?[/QUOTE]
Dave
Saw about 0.75ish whilst in 3rd overtaking Damn 40mph Tesco lorries on the blat to work this morning.
If you give a large welly 4th it climbs to just over 0.65
Good / Bad ????????????????
Chris
Gibbo
Post 12985 by Wobbly Dave on 2005-04-06 11:16:58
Open the drivers door
Pull back the rubber seal off the frame - exposing the bit next to the end of the dashboard.
Undo the 3 screws to release the plastic cover above the pedals and pull the cover out from the slots on each side.
Depending on what you have on the gauge - you can either chocolate box or use spade connectors on the end of the wires coming out the gauge.
Get 2 lengths of wire - 5 amp is more than enough - about 18 inches long.
Thread the wire into the gap between the end of the dash and the door frame.
Remove the headlight switch from the dash, either by reaching inside the dash from the footwell or by prising it out with a screwdriver or pulling on the knob.
Feed the wires up and through the hole where the light switch is.
Twist the bear end up on the live wire (I used red and black wires) and wedge it into the back of the switch (I think it is position 4) where the blue and yellow wire comes out on the top row of the connector.
Do the same for the other wire and wedge it into the end connection where the black wire comes out.
Feed the other end of the wires behind the plastic fascia at the end of the dash where the air comes out to blow on the window.
Connect up to the gauge.
Put all the trim back into place. Put the cover in the footwell into place (make sure you get the slots into the right place on the hinges either side) and screw it back up.
Turn on the ignition to ensure that the connection is good before pushing back the switch into its hole.
JOB DONE :beer:
Drink beer and be happy!
Post 12987 by Wobbly Dave on 2005-04-06 11:19:53
[QUOTE=gibbo]Dave
Chris
Gibbo[/QUOTE]
I'd say fair to fairly good. But we know that from what you said that there are a few niggles to work out. If she spikes to .75 and holds at .65 then there is promise there.
Post 12993 by Wobbly Dave on 2005-04-06 11:27:02
You are welcome. Shame I have no pics.
This method assumes you are using an A pillar pod mounting.
Post 12994 by Unknown on 2005-04-06 11:28:37
[QUOTE=dave850R]You are welcome. Shame I have no pics.
This method assumes you are using an A pillar pod mounting.[/QUOTE]
I was planning on wireing mine in - I'll take some pics as I do sometime in the next week.
Andrew.
Post 12996 by Wobbly Dave on 2005-04-06 11:39:20
Cheers Andrew. If you use my instructions and you feel they can be improved then by all means do.
Post 12997 by gibbo on 2005-04-06 11:56:35
[QUOTE=dave850R]I'd say fair to fairly good. But we know that from what you said that there are a few niggles to work out. If she spikes to .75 and holds at .65 then there is promise there.[/QUOTE]
Cool,
I'll have a proper look at it in the next few days.
It did spike higher than .75 but not much (i looked as it was coming down)
So yeah looks promising he he
Cheers Dave
Gibbo
