Post 133449 by t5tart on 2006-08-12 11:43:53
now i know this work is not cheap but £800 jeeeeeeeezzzzzzzzzzzzzzzzzzzzzzzz anyone know where i can get a competative quote ?
what about diy? used to work with b series and x-flows.. unless you are doing serious mods (and then you are spending mucho mula) you only need to smooth the flow of gas in and out try it on a spare head - if it don't work you haven't lost out there you go just read you got a spare....
tching the manifolds to the head etc etc and wanted a 3 angle job its not quite that simple though as smothing it out the inlet side doesnt want to too smooth or it wont disturb the air enuff to mix it properly maybe ill just stick with it standard was going to pre empt a biger turbo etc and get it done before i went down that route
There is a guy on here selling an engine with a newly ported and flowed head - He did not put the engine in his car due to it chucking out all the water so he went and bought a new one! I think the head is still on it and since he has said the engine is crap he is willing to let it go for not much. It may be worth buying if only for the head!
[QUOTE=Bigtony]There is a guy on here selling an engine with a newly ported and flowed head - He did not put the engine in his car due to it chucking out all the water so he went and bought a new one! I think the head is still on it and since he has said the engine is crap he is willing to let it go for not much. It may be worth buying if only for the head![/QUOTE] any ideas who it was Tony?? as you know i already have a head of your car lol
Ill go have a search and get back to ya!
Hi mate Its anogg3 - his thread is in Volvo Items for sale
[QUOTE=Bigtony]Hi mate Its anogg3 - his thread is in Volvo Items for sale[/QUOTE] cheers bud
hey matey dont look like that one is flowed just been skimmed skimming aint a problem but getting it flowed seems to be the expensive bit
Whats hard about porting a head?, as has already been said, do it yourself!. I wouldnt worry about keeping the inlet rough enough to mix the air/fuel, as long as your not polishing it you won't have any problems. Main thing to do is to take out any sharp corners/steps in the manifolds/ heads, also remove the big step where the manifold joins the head. Once you've ported it yourself get the three angle valves and seats quoted for, should be a lot cheaper.
http://www.kalmar-union.com/ have a look here m8. still xpensive though but there is a lot of work involved. ie cutting all valves 3 times.
