Post 132235 by monkey_boy on 2006-08-08 10:08:28
I have a strange judder from the front of my C70.
Its constant whilst driving and gets worse with speed. I recently had new tyres and they where balanced with about 12psi in them. Would this mean after correcting the pressure they are out of balance? The stearing wheel doesnt shake but i can feel the judder through the floor and under my seat!
The roads i drive are not the best and it does change with road surface. It also lessens when i turn.
I will of course get the tyres re-balanced but anyone have another thought?
Post 132238 by Unknown on 2006-08-08 10:36:34
Make sure your wheel nuts are tight enough - we jest but Martin K found 4 of his almost out when he had similar noises :)
Post 132248 by monkey_boy on 2006-08-08 11:50:10
"gulp" i'll have a check!
Post 134607 by sregan on 2006-08-15 20:39:46
"Make sure your wheel nuts are tight enough"
A quick question that I was wondering about asking and this seems to be a good opportunity. With regards to tightness of wheel nuts, what is the recommended torque setting? (I wanted to check my nuts, so to speak!)
Post 134609 by T5ER on 2006-08-15 20:41:52
LOL i keep checking my nuts, as for torque settings not sure but someone will know
Post 134624 by sregan on 2006-08-15 21:02:45
[QUOTE=T5ER]LOL i keep checking my nuts, as for torque settings not sure but someone will know[/QUOTE]
I knew it wouldn't take long before I saw a reply like that...LOL, same here mate...my missus wont do it!
Post 134729 by T5ER on 2006-08-15 22:48:48
I know what you mean she dont know how to use the torque wrench
Post 134861 by t5tart on 2006-08-16 16:00:08
just checked haynes
its 110 on an 850 anyway
Post 134928 by iGGy on 2006-08-16 17:37:34
110Nm not ft-lbs...wee bit of a difference
Post 135278 by sregan on 2006-08-17 19:44:14
thanks for that! Were your wheel nuts tight enough Monkey Boy?
