Post 125302 by akky on 2006-07-13 15:59:01
The leccy mirror on the drivers side isn;t working, also the option to retract the mirrors only works for the left side.
I've looked at the fuse info and everythin else appears to work on that is on the same fuse.
I suppose I'm looking at a new mirror motor. or is there a known fault on the v70's
thx
Steve
Post 125335 by Baj on 2006-07-13 19:04:54
I would thing the switch is a more likely candidate. Must get round to fixing mine at som e point
Post 125420 by T-5ones on 2006-07-13 23:27:02
You could check the contacts of the plug etc after checking switch. (i know its a pain taking off the door skin) I only found the reason for my one not working when upgrading my speakers.
Post 125467 by akky on 2006-07-14 09:03:38
thx guys, sounds feasible, will check out the switch
Steve
