Post 125055 by LeeVTi on 2006-07-12 21:42:21
ive just changed the top engine mount on my T4 and the clunking sound is still there, i was told that the noise i was getting was the mount as they are known to go, but after changing the mounting and further inspection (many hours of puzzling and guessing, then second guessing) it appears to be coming from the gearbox, the only way to describe it is as a clunk type noise, metal on metal, this only seems to happen when accelerating, or when you come off the throttle and step on it again, all signs lead to an engine mount, but now im stumped and this i feel will again be expensive
any ideas guys, my thoughts are now either box or diff, anybody heard of this before....really stuck
and its in for its 90'000mile service on tuesday with VT but would like to have an idea of what it is before i get there if at all possible.
all ideas and thoughts appreciated
Post 125059 by T5ER on 2006-07-12 21:46:06
could be either gearbox mount or lower engine mount mate also check the bushes in the gear linkages,does the stick feel slightly sloppy/loose
Post 125062 by t5tart on 2006-07-12 21:46:52
vt will tell you what it is
Post 125087 by Mrsmopp on 2006-07-12 22:02:59
Sounds like your describing a knackered gearbox mount
x
Post 125174 by LeeVTi on 2006-07-13 04:33:38
[QUOTE=T5ER]could be either gearbox mount or lower engine mount mate also check the bushes in the gear linkages,does the stick feel slightly sloppy/loose[/QUOTE]
no mate stick feels ok to me, will order the other mounts it has 2 lower an 1 on the gearbox i'll change them all and see what happens
Post 125602 by LeeVTi on 2006-07-14 17:03:39
ok, now im starting to get slightly annoyed with the whole thing, just spent a couple of hours replacing the last 2 mounts this afternoon, so i have a brand new set of 4 engine mounts on my car, upper engine, upper gearbox, and the 2 lower front and rear, and guess what.....
no differance in the "clunking" still just as loud and just as noticable....any more ideas to check, im still now thinking about diff/gearbox or maybe even a worn clutch, it doesnt appear to have had a new 1 in 90000 miles i cant find a reciept for 1 in the history i have of the car (which is very extencive), but there doesnt seem to be any loss of drive so maybe not clutch, at the end of my tether with it now................:cussing:
Post 125690 by mikej on 2006-07-14 22:42:57
Get it on a ramp or even in the drive if you have to and get some one else to dip the clutch etc you may be able to see something then ? don't take this the wrong way but its not your exhaust swinging on the rubbers is it?? really needs to go up on the ramps i think!!
Post 125692 by t5tart on 2006-07-14 22:49:24
you sure its not a suspension mount?
or a linkage
Post 125750 by kimbaleeg on 2006-07-15 02:28:02
isit clunk when driving over bumps could even be shockers if it does
Post 125752 by LeeVTi on 2006-07-15 04:34:21
ive had the front wheels in the air and put it into gear and looked under the bonnet whilst somebody has pressed the throttle, and you can see the engine move slightly (normal)but you can hear the almighy clonking noise when its put under any load and the same noise when you come off the throttle, i can only narrow the noise down to the left hand side of the engine bay, ive looked from the top, and underneath in all possible conditions, well all that you can manage with a couple of axle stands, i havent been looking at the exhaust though might give that a look failing all this i think it will be a job for VT just hope it doesnt work out to expensive
Post 125764 by t5tart on 2006-07-15 10:09:27
seems to me it could be suspension related if it doesn't do it when the weight is off the suspension??
surley if it was an engine mount it would clunk wheels in the air or not
Post 125798 by LeeVTi on 2006-07-15 13:25:59
sorry if i didnt explain my last post it does clunk when the wheels are up in the air, would it still do this if suspention related? im at a total loss
Post 125800 by t5tart on 2006-07-15 13:28:01
could well do
might be a worn top mount
Post 125806 by LeeVTi on 2006-07-15 13:41:23
are these common on the s40 do you know?
Post 126198 by stuAWD on 2006-07-17 13:18:19
Dont know what the T4 engine is like, but had a similar problem with mine, turned out to be the rubber in the lower right engine mount had collapsed. Couldn't tell until it was up in the air and lifted the front of the engine slightly with a gearbox jack.
Post 126472 by jimka on 2006-07-18 02:55:39
does it make this noise with the clutch pedel fully pressed in?
Post 126518 by LeeVTi on 2006-07-18 12:26:38
now ive changed the engine mounts it makes the noise on gear changes and when you let off the throttle after hard acceleration
Post 127472 by Bison on 2006-07-21 20:32:46
Lee, I'm pretty sure I have exactly the same thing on my T5, and it is hard to explain and make people understand. If for example your in 3rd gear and you accelerate and let off it clunks as the gear engages and disengages the drive? Do you have some slight play before it picks up the drive just before the clunk?
I thought it was my clutch or flywheel, which I have just had replaced along with some other work costing me just over £800 and guess what still got the clunk...I was so upset after spending all that money. I phoned the garage and he said he checked all of my mounts and when doing clutch etc had gearbox mounts off, he said they are all fine. So he thinks it can only be play in the Gearbox.
I have read on other threads that the diff bearings can go in them, which would mean a new box is required as they cannot be stripped down. Its a bitch huh. Im off to VT on the 28th July so will ask there opinion but i'm not optimistic.
Bison
Post 127478 by Neilly on 2006-07-21 21:32:40
Have you checked your driveshafts ,I had similar probs on my old Vectra,turned out to be the driveshafts in the end after changing mounts etc.Jack it up feel for any play???? Remember jacking it up one side at a time starting it up putting it in gear and there was a almight clunk coming off the nearside wheel when i revved it up
Post 127578 by Bison on 2006-07-22 02:03:13
My friend drove my car tonight, he's convinced its an engine mount....The saga continues.
Bison
Post 127639 by LeeVTi on 2006-07-22 12:58:41
ive just spent £300 in new mounts from the dealer and to no joy, i also yesterday took it to a gearbox specialist and he drove the car and said that in his opinion that the gearbox was fine, as much as he would like to take my money to take it apart he said it was all ok, he did however say that it was possible the noise was somewhere on the gear linkage as its a metallic clunk, ive spoke to hamsih at VT aswell when my car went for a service and he was unsure as to what it is?? very strange
Post 127688 by Bison on 2006-07-22 17:25:28
Well, as I said, i'm up at VT on the 28th so will let you know if he discovers what is causing it.
Bison
