very good site
Post 124600 by volvos60t5 on 2006-07-11 21:30:43
This man works for volvo on the engine development department and has a vast amount of knowledge. The good thing is that it puts some of that knowledge on the internet: http://www.wothrline.com/main.html
Post 125202 by oddjones on 2006-07-13 10:11:55
... But what on earth are "roof cunnings"? - it all sounds very rude to me
Post 125222 by lance on 2006-07-13 11:05:48
Actually I beg to differ, He obviously he is very passionate and spends a lot of money on his car but I belive he has been feed a fair amount of Cack.
As Ive seen much more favorable results without doing a lot of that stuff!
Post 125227 by volvotuning on 2006-07-13 11:09:23
Lance, indeed if you read the first page you will see that this site is all about his own findings and that anyone is entitled to disagree. To quote his last sentence -
"I will NOT debate the information from this site on any Internet forum. This is my personal experiences and if someone doesn't agree it's their right not to do so."
Adam.
Post 125233 by T5ER on 2006-07-13 11:27:48
I do like his car though oh i am so in love need to spend a bit of cash to get mine in this condition
Post 125241 by lance on 2006-07-13 11:43:17
[QUOTE=T5ER]I do like his car though oh i am so in love need to spend a bit of cash to get mine in this condition
[/QUOTE]
Yeah it does look the part, Mine also needs a make over too, Front tyres , suspenders, rear discs & pads, front pads atleast, also chav dint taking out rear passanger door , and bleedin car park scrape out of back panal. Having new AC pipe next week so atleast I can be chilled about it all!
Post 125242 by volvos60t5 on 2006-07-13 11:50:50
In my opion the guy nows more about this stuff than most of us. Take for instance his opion on injectors. I know for sure that there will be a lot of experts here who will disagree but after carefull reading I agree with him:
"Fuel injectors
Too many people and tuning companies seams to forget that the engine need fuel in order to perform and if you don’t upgrade your car with bigger injectors above a certain level of tuning, the power will simply not be there. Too choose fuel injectors is not so difficult as long as you keep in mind that there has to be margins for component protection so that the injector is not run wide open. There are exact formulas to calculate size of fuel injectors, but bellow are some guide lines concerning the most common fuel injectors used in B52x4Tx engines. We know that maximum performance is obtained at lambda between 0.91 and 0.93, but it’s often a delicate task to keep lambda at optimum air/fuel ratio for a longer period due to heat in exhaust system and internally in the cylinder. In real life this often means that after a period of time the system will have to engage component protection and run with a richer air/fuel ratio in order to cool the hardware and then lambda 0.83-0.85 is what I regard as a good compromise for performance and safety as long as temperatures are within the limits. Maximum component protection may demand as rich as lambda 0.7 or richer and that you will have to bear in mind when choosing fuel injectors. Make sure that your injector size can handle lambda 0.7 at desired power output. Lambda 1 is equal to A/F ratio 14:1.
Volvo fuel injectors Lambda value (A/F) Power
468cc (349gr/min) 1 468hp
0.92 430hp
0.85 398hp
0.8 374hp
0.7 328hp
394cc (294gr/min) 1 394hp
0.92 362hp
0.85 335hp
0.8 315hp
0.7 276hp
350cc (261gr/min) 1 350hp
0.92 322hp
0.85 298hp
0.8 280hp
0.7 245hp
315cc (235gr/min) 1 315hp
0.92 290hp
0.85 268hp
0.8 252hp
0.7 221hp
310cc (231gr/min) 1 310hp
0.92 285hp
0.85 264hp
0.8 248hp
0.7 217hp
Example none stock fuel injectors
Fuel injectors Lambda value (A/F) Power
725cc (541gr/min) 1 725hp
0.92 667hp
0.85 617hp
0.8 580hp
0.7 508hp
550cc (410gr/min) 1 550hp
0.92 506hp
0.85 468hp
0.8 440hp
0.7 385hp
Knowing the size of the fuel injector let us determine what power output is reasonable to expect from the setup. If we calculate that our setup can hold the power output at lambda 0.85 without running to hot we can also see that many performance figures presented to us in media, on the Internet etc are quite hard to believe. There are no stock Volvo fuel injectors big enough for 500hp and even 400hp is hard to reach. Bigger injectors cost money and it’s also more difficult to control a big injector at low flow rates and therefore car manufacturers will not choose injectors that have capacity high above the expected need. Too big injectors can affect idle performance, emissions, cold start behaviour etc.
The 225hp 850 Turbo with B5234T engine had 310cc injectors and also the 850 T-5R and the automatic 850R with B5234T5 and 240hp used these 310cc injectors. When the manual 850R with 250hp B5234T4 engine was introduced it came with 350cc injectors and the 350cc injector was used for 240hp x70 T5 and automatic R with B5234T3 engine and manual R with 250hp and B5234T4 engines.
P2x T5 with B5234T3 engine came with 394cc fuel injectors and the 394cc fuel injector is also used for the new 24HT engine in P2x T5 2005- with 260hp B5244T3 engine. The new 300hp R-line engine B5254T4 in S60R and V70R introduced comes with 468cc fuel injectors. As you can see the fuel injector size has increased quite significantly from the 225hp B5234T engine to the 300hp B5254T4 engine. If it was possible to reach 300hp and still obtain all demands on the system you can be 100% sure that Volvo, or any other car manufacturer for that matter, would never have changed to bigger fuel injectors, but it is simply not possible to use a 310cc fuel injector in a 300hp setup and still fulfil all the demands.
A SW upgrade with no HW upgrade like exhaust system will make your car run hot and then lambda 0.7-0.75 is what you can expect quite soon at maximum load…
Bear this in mind when you check for upgrades that claim to give your car +300hp with stock HW and chip upgrade including sport air filter.
High air flow through the engine with a low back pressure in the exhaust system will cause less heat and therefore allow a more efficient lambda value with high performance as a result, but this also has to be considered in the SW-calibration in order to make a difference. Fuel injector size will have to be chosen in consideration with turbocharger and exhaust upgrade in order to reach a good solution.
Lambda 1 or A/F ratio 14:1 is the optimum mixture for emissions and running either richer or leaner will affect emissions creating either higher NOX level or higher CO2 levels with increased fuel consumption as a result.
This image is just to show the principal in general."
Post 125250 by volvotuning on 2006-07-13 12:24:49
[QUOTE=volvos60t5]In my opion the guy nows more about this stuff than most of us. Take for instance his opion on injectors. I know for sure that there will be a lot of experts here who will disagree but after carefull reading I agree with him[/QUOTE]
That's the great thing about living in a democracy! We can agree/disagree and everyone is happy :) Everyone has their own experiences, and my own experience lead me to disagree with some of the stuff he writes. However some of the stuff I do agree with. Let's face it, even Volvo engineers can make mistakes - they are human after all, just like the rest of us.
Adam.
Post 125264 by Matt30462 on 2006-07-13 13:28:24
I dunno, I lost track of this thread on "Cunnilingus"
Post 125283 by T5ER on 2006-07-13 15:15:09
Does this mean i can buy the 350cc injectors and do a straight swap for my 310cc or would it confuse everything if i just swapped them
Post 125285 by volvos60t5 on 2006-07-13 15:20:25
[QUOTE=T5ER]Does this mean i can buy the 350cc injectors and do a straight swap for my 310cc or would it confuse everything if i just swapped them[/QUOTE]
Depending on the current settings the start migth be a bit rough but the software will take cart of that after start. My car ran the the original sofware (for white injectors) after I put in the green injectors. It was a bit rich mixture dough:biggrin: You are howver better of changing the software if you change injectors.
Post 125286 by volvotuning on 2006-07-13 15:21:31
If you swap those injectors, closed loop fueling will be ok (ECU will adapt), but WOT open loop fueling will be too rich. Then you will need a remap to fix that.
Adam.
Post 125288 by T5ER on 2006-07-13 15:27:17
[QUOTE=volvotuning]If you swap those injectors, closed loop fueling will be ok (ECU will adapt), but WOT open loop fueling will be too rich. Then you will need a remap to fix that.
Adam.[/QUOTE]
Ta for that thought i would check first may have to get them and then pop down to you guys for a remap,would it up the bhp any more than standard or not
Post 125289 by volvotuning on 2006-07-13 15:28:44
[QUOTE=T5ER]Ta for that thought i would check first may have to get them and then pop down to you guys for a remap,would it up the bhp any more than standard or not[/QUOTE]
Nope, no extra bhp at all.
Adam.
Post 125291 by BrightonBreezy on 2006-07-13 15:32:28
Adam,
On his project car he also makes use of the exhaust manifold from the new 'R' engine. Do you know how much difference that makes? Is it worth the cost of buying one?
Post 125292 by T5ER on 2006-07-13 15:35:33
[QUOTE=volvotuning]Nope, no extra bhp at all.
Adam.[/QUOTE]
LOL wont bother with that then will just pop down and get the RICA now which one to go for???
Post 125293 by Mrsmopp on 2006-07-13 15:36:45
Am I going mad or is this a bit of de ja vous?? Was this website and its content debated some months/years back or am I thinking of something else entirely?
x
Post 125296 by T5ER on 2006-07-13 15:39:15
Dont know MM,link finding time i think
Post 125297 by volvotuning on 2006-07-13 15:44:59
[QUOTE=BrightonBreezy]Adam,
On his project car he also makes use of the exhaust manifold from the new 'R' engine. Do you know how much difference that makes? Is it worth the cost of buying one?[/QUOTE]
Exactly how much difference it makes I'm not entirely sure because I haven't made any appropriate measurements on the same car with only the manifold changed as a direct comparison. I do think it makes a small difference but whether it's worth doing depends on how bothered you are about extracting the best from the car.
Adam.
Post 125298 by volvotuning on 2006-07-13 15:45:52
[QUOTE=Mrsmopp]Am I going mad or is this a bit of de ja vous?? Was this website and its content debated some months/years back or am I thinking of something else entirely?
x[/QUOTE]
Yes it was! Yes it is de ja vous! :)
Same recently happened on the voc about injectors :) lol.
Adam.
Post 125299 by BrightonBreezy on 2006-07-13 15:46:29
[QUOTE=T5ER]get the RICA now which one to go for???[/QUOTE]
Presumably the one that suits your car.
BTW, do you spend ALL your time on this forum? How does someone make 1700+ posts in 3 months? Do you ever leave the house to actually drive your car?
Post 125300 by Mrsmopp on 2006-07-13 15:52:41
[QUOTE=volvotuning]Yes it was! Yes it is de ja vous! :)
Adam.[/QUOTE]
Curious hey!! ;)
x
Post 125301 by T5ER on 2006-07-13 15:57:38
[QUOTE=BrightonBreezy]Presumably the one that suits your car.
BTW, do you spend ALL your time on this forum? How does someone make 1700+ posts in 3 months? Do you ever leave the house to actually drive your car?[/QUOTE]
Actually yes i do as i have been signed of on the sick for 4 weeks due to a back injury mate so i cant drive my car for long periods or sit for long periods.I may also have to go for a operation if the morphine injections into my spine and physio dont work
Post 125303 by BrightonBreezy on 2006-07-13 16:08:24
I'm sorry to hear that. Hope you feel better soon.
Post 125304 by T5ER on 2006-07-13 16:11:05
[QUOTE=BrightonBreezy]I'm sorry to hear that. Hope you feel better soon.[/QUOTE]
So do i its driving me mad,I have a high post count as i work for volvo aswell and have a lot of friends on here
Post 125310 by Matt30462 on 2006-07-13 16:52:03
Rubbish!!!!!
It's just that he never leaves his computer, never leaves this site and is paying some Lithuanian Student Doctor Immigrant Person £10.00 a week to give him sick notes.
:kiss: :kiss: :kiss: :kiss:
Post 125314 by T5ER on 2006-07-13 17:03:26
now there was no need for that :sorry:
Post 125324 by Matt30462 on 2006-07-13 17:59:31
:kiss: :kiss:
Back to the subject
:kiss: :Handshake :Handshake :kiss:
Post 125325 by T5ER on 2006-07-13 18:01:56
[QUOTE=Matt30462]:kiss: :kiss:
Back to the subject
:kiss: :Handshake :Handshake :kiss:[/QUOTE]
:Handshake :Handshake :Handshake :kiss: :kiss: :kiss: :Handshake :Handshake :Handshake
Post 159842 by MacXC60T5 on 2006-11-09 16:15:57
Its now 9-11-2006. This topic was getting very interesting and then it stopped. is it carried on elswhere. nothing for 4 months so I suppose its DEAD
Post 159843 by pzorb on 2006-11-09 16:36:07
Would it be the case that bigger injectors do not increase your HP, but prevent it from dropping off as much? In the same sense that a bigger intercooler gives no great power increase (if any) but does help keep it high.
Post 159845 by volvotuning on 2006-11-09 16:47:52
[QUOTE=pzorb]Would it be the case that bigger injectors do not increase your HP, but prevent it from dropping off as much? In the same sense that a bigger intercooler gives no great power increase (if any) but does help keep it high.[/QUOTE]
Only if you are running out of fuel.
Adam.
