Recieved my new Cd changer......
Post 124593 by ammo1981 on 2006-07-11 21:23:49
elo. I ordered a ALPINE CHAS624 6-CD Changer a few days ago and had it delivered this afternoon. I went to pull out the headunit (SC 901) and found the "CD" marked socket allready occupied by a cable. Ive looked under the seats and every where in the boot to see if i can find the other end. Have i missed a place or is it best i use the supplied wiring/cabling??? Also, with the cd changer came something that looks like a junction box with two wires hanging out. Apparently it needs to be connected to a power source. Where do i find that?
Post 124699 by Paul on 2006-07-11 23:42:37
dont the multi changers go in the boot?
Post 124714 by t5tart on 2006-07-12 00:25:00
yer changers usually go in the boot look in the rear of the boot behind the carpeting try the electric areial side that would be my first place to look the junction is a noise reducer i reckon pover sourse can be picked up fronm the wiring loom on the passengerside of the car ..plenty of power there for the electris like areil alpine cableing is of very good quality no telling hwhat has been put in before i would re run it but depends how easy an install you want but should be easy enuff to tuck it under the carpet down the side of the doors where did you want to mount the changer ??
Post 124986 by kimbaleeg on 2006-07-12 19:47:07
[QUOTE=ammo1981]elo. I ordered a ALPINE CHAS624 6-CD Changer a few days ago and had it delivered this afternoon. I went to pull out the headunit (SC 901) and found the "CD" marked socket allready occupied by a cable. Ive looked under the seats and every where in the boot to see if i can find the other end. Have i missed a place or is it best i use the supplied wiring/cabling??? Also, with the cd changer came something that looks like a junction box with two wires hanging out. Apparently it needs to be connected to a power source. Where do i find that?[/QUOTE] ive recentley been thinking ov this my self and found the plug is occupied i looked in the boot passsenger side under carpet under electric ariel there was two connectors there ones defo the other end from radio but the other is a different connector this may help u alittle
