aircon recharge
Post 122004 by monkey_boy on 2006-07-05 09:13:52
Anyone know where the aircon recharge connection is? I have located one connector (the cap has "max 6Nm" on it. but i cant see another. The "aircon" expert from Halfords didnt have a clue admitting never having seen under the bonnet of a T5 before. I know a recharge place but i want to make sure that the guy doing the work knows where he is pumping coolant! Any ideas?
Post 122018 by T5ER on 2006-07-05 09:54:25
mine has only got one aswell ???? dont know mate
Post 122082 by dreadly on 2006-07-05 11:54:56
I have got the same problem..... - But the theory goes something like this... The cap at the top is apparantly for evac (evacuation of the system) - the port you need is the low pressure port just before the compressor. I havn't found it on my S60, but I havn't been able to have a good look yet, theory says it should be as close to the pump as possible, I suspect access to it will be somewhere under the front offside wheel arch near the compressor. I was however told by a guy who is a qualified air-con engineer that not all cars support low-pressure gassing, some cars have to be pressure filled or have a port fitted to the low pressure side!
Post 122105 by NugentS on 2006-07-05 13:49:56
The modern cars have two points, 1 high pressure and 1 low pressure. The recharge cycle doesn't take terribly long. The older cars only have 1 point and you need to hold a vacuum for about 40 minutes before charging. Sean
Post 122108 by dreadly on 2006-07-05 13:56:54
[quote=NugentS]The modern cars have two points, 1 high pressure and 1 low pressure. The recharge cycle doesn't take terribly long. The older cars only have 1 point and you need to hold a vacuum for about 40 minutes before charging. Sean[/quote] Out of interest.... What do you class as modern, mines an '03' reg - reg-July 03 Mine only appears to have one port, it's blady confusing.
Post 122118 by monkey_boy on 2006-07-05 14:31:24
Hmmm. I have a workshop manual on CD. I think i may take a look at that. However it is an eBay one so i wont hold my breath. If anyone does find out/know. Please continue the thread :) I have a 2000 C70 T5. I would class that as modern (ME7 lump). I had a bloody good nose under the bonnet. I can only see this one cap. It is pretty close to the reservoir. How do you hold a vacuum for 40 minutes?
Post 122172 by Rbphot on 2006-07-05 17:11:41
Hi Just had my AC serviced yesterday at SWauto's and my 98 V70R only has one connector, but stu did say all newer volvos come with two, so it must be there somewhere. As for the vac and fill you need the proper specialist kit, mine was on the system for about 45-60mins, then leak sealer and a booster added before oil and gas refill. The vent temps went down to 9.8 0cwhen measured at vent, it felt soo good driving back to london!
Post 122222 by Unknown on 2006-07-05 19:09:32
Your local dealership might be offering a service on your air con at £40. Doesn't sound that bad to me, although Stratstone Stockport have a 3 week wait!
Post 122224 by waynebaggies on 2006-07-05 19:10:28
expert from Halfords you having a laugh if it's not a push bike or a tin of wax they aint got a clue
Post 122274 by t5tart on 2006-07-05 22:22:30
mine has 2 but i think its a retro fit on ontop of the dryer already shown and this one under the top engune mount Image
Post 122410 by monkey_boy on 2006-07-06 09:23:33
Yeah. My Halfords "expert" was meant in a sarcastic way :) The kid didnt have a clue. He couldnt even open the damn bonnet!
Post 122412 by t5tart on 2006-07-06 09:32:13
haha well they are tricky with those catches..i mean his one braincell was probably admiring a piece of skirt
Post 122423 by NugentS on 2006-07-06 10:38:41
[QUOTE=dreadly]Out of interest.... What do you class as modern, mines an '03' reg - reg-July 03 Mine only appears to have one port, it's blady confusing.[/QUOTE] Hmmm - dunno. I though much past 98/99 had two points. But it seems that I am wrong. Maybe its S60's etc have two points. Sean
Post 122573 by dreadly on 2006-07-06 20:30:34
WOW, I have just found the low pressure input port on the S60, it now becomes so clear!!! - Of course... It's underneath the power steering fluid reservour! - Where bloody else would it be for easy access. Not being sarcastic or anything, but come on vovlo, whats that about?
Post 122646 by audimadmike on 2006-07-06 22:48:12
Its on the pipe coming from the evaporator (with the heater matrix) to the compressor, its always on the side of the compressor with the largest pipe diameter. the smaller pipe goes to the condenser (radiator) the high pressure side. From memory I believe it is the connection in the first photo posted. A vacuum is held with a vacuum pump and is THE ONLY way to remove air and moisture before adding gas. This is why the Halfords kits are not much use. You can't top up a leaking system..its illegal (£20,000 fine and 5 years inside!!) if caught. And if there is no gas in the system you can't just add gas because there will be air in the pipework. Mike
Post 122649 by Vikingxl on 2006-07-06 22:59:24
I was about to recommend looking you up Mike!
Post 122947 by audimadmike on 2006-07-07 21:52:55
[QUOTE=vikingt5]I was about to recommend looking you up Mike![/QUOTE] Cheers mate, its nice to be able to help. Mike
