Post 120024 by monkey_boy on 2006-06-28 14:04:38
With all the woes of my service and ETM stuff a the moment i forgot to ask a question about my interior clock.
I dont have a computer just a clock and temp readout. It all looks ok with the digits in place and the temp changes so i guess thats ok. However the clock is stuck at 13:23. I change it and it stays to whatever i change it too. regardless.
Any ideas whats up?
Post 120025 by Azza on 2006-06-28 14:07:19
No idea to be honest, but it sounds like you need to maybe push the button to set it again, seems like it's stuck on "set" mode.
Although that sounds like a far too easy solution :)
Azza
Post 120028 by monkey_boy on 2006-06-28 14:17:58
Funny. I thought a similar thing but i dont know where the set button is. I'll check the manual again tonight. Cheers Azza :)
Post 120029 by Azza on 2006-06-28 14:24:29
Hmm, i can't remember either, do you just press the minutes/hours buttons and they advance ? Or do you have to press a different button first to make the figures flash or something, to enable you to change them...? Much like a "normal" digital clock...
Azza
Post 120035 by Wobbly Dave on 2006-06-28 15:43:41
I have a spare C70 binnacle that matches yours (no computer) should you find it will not fix.
Post 120309 by monkey_boy on 2006-06-29 14:31:00
I had a look in the manual (no help) and its just a case of pressing the hour or minute button. There is no other button or reset switch. i'm stumped. May get a replacement at some point but funds restirct it at the moment ;)
