Post 119299 by monkey_boy on 2006-06-26 11:14:25
Just had marshalls (cambridge) Volvo's report on my car. The erratic idle was the airflow mass sensor not the ETM as i was dreading (although still £152) Just in case anyone else has the irratic idle problem. Its not all grim possibilities :)
Post 119312 by SaffronC70 on 2006-06-26 12:11:46
Hi
Are they letting you do the MAF ?
Chris
Post 119317 by monkey_boy on 2006-06-26 12:45:09
[QUOTE=SaffronC70]Hi
Chris[/QUOTE]
No they just siad it needed fitting and they dont have it in stock. They made some noise about the torque bar bush (uprated) i asked for but told them definatly not to fit it.
Its in for a service anyhow and timing belt (at 88500 miles) because the lying b@stard i bought it from didnt actually have it changed when the service book says (Volvo stamp but no mention of belt change)
Post 119324 by monkey_boy on 2006-06-26 14:04:00
Looks like they have removed the original already without a spare to replace. Looks like i will be driving the V50 courtesy car home tonight!
Post 119403 by roadrunner on 2006-06-26 18:04:01
anyone know how the plastic tube comes off the etm. I tried today and it would not budge. just like to inspect the etm then go from there. bolts are a pain to get to even with a mirror. In the end i gave up due to rain and grazed knuckles
Post 119414 by SaffronC70 on 2006-06-26 18:34:31
Jubliee clip - feel around for it and use a 7mm socket on it. May need persuading to come down.
The bolts (as you could see with the mirror) go around the intake - much easy to take off with the tube not in the way.
Chris
Post 119423 by roadrunner on 2006-06-26 18:57:41
Thanks for that. there is no jubilee clip on my hose and when i tug at it the hose comes away 3mm or so but leaves the part where the jubilee clip should be so i think i may need a new one!!.May be the cause of the uneven idle?
Post 119427 by SaffronC70 on 2006-06-26 19:00:10
Could well be !
Good luck.
Chris
Post 119762 by monkey_boy on 2006-06-27 17:01:01
Mass airflow sensor changed. Cleared the fault codes but it also needed the ETM cleaning (along with throttle body). The dearest service i have ever had (by about 3x!) At least its going to be spot on after i get it back :)
Post 119764 by SaffronC70 on 2006-06-27 17:03:54
You hope !
I had 2 MAFs, 3 ETMS and all it was, was those pesky one-way valves.
Chris
Post 119766 by monkey_boy on 2006-06-27 17:21:54
I was worried for a second. Those where the first things i checked and then had rechecked. I also have it from the horsers mouth that the dealer wont charge me for the cleaning (2.5 hours aparently) if it doesnt solve it.
Post 124596 by -Nathan- on 2006-07-11 21:25:42
[QUOTE=SaffronC70]You hope !
Chris[/QUOTE]
Hi - could you elaborate on the "one way valves" ?
Cheers
Post 124851 by monkey_boy on 2006-07-12 13:15:20
[QUOTE=-Nathan-]Hi - could you elaborate on the "one way valves" ?
Cheers[/QUOTE]
http://www.vpcuk.org/forums/t10003-p2-uneven-idle.html
Here you go. A useful thread. I checked my valve in about 5 minutes. Its very easy to do.
