hot starting problem
Post 117004 by t5tart on 2006-06-17 15:51:30
only since the weather got hot if i run the t5 and then pop in a shop leave it stood for 5 mins and get in and restart it it starts then dies b4 leveling the tickover then it wont start without letting it stand a couple of mins anyone got any ideas ?
Post 117832 by t5tart on 2006-06-20 20:00:52
no one any clues hints or tips ??
Post 118272 by motly crue on 2006-06-22 14:47:35
Hi mate,you could check one of these 1.your eletrical connections-engine or battry 2.fuel pump non-return valve 3.fuel pressure/dilivery rate/fuel pressure regulator 4.fuses/fuel pump/you'r engine control relay/relay module 5.crap in your fuel/fuel filter 6.injectors 7.ignition system 8.air filter 9.air intake system/vacume system-leaks ckp,evap,cmp sensor,vaf,tp,maf,map,etc,ecm,etc,tp,your engine compression. exhaust system or the cat, have you check'd if you have any fault codes coming up? hope this gives you some help whith your problem:)
Post 118873 by Niles on 2006-06-24 14:55:42
Ive got the same problem, my outside air temp says 40+c, I have to let the engine cool before it'll start, when it duz it 'hunts' for a minute or 2.
Post 119239 by t5tart on 2006-06-25 21:59:17
ok done a full stage 0 recently new vac lines filters inc fuel no fault codes i would hae thought half of those problems would be picked up by the ecu ??
