Post 114187 by nobananas on 2006-06-05 21:17:58
One of my customers is complaining that the radio in his 97' 850 is making odd noises. When tuned to an LW or MW frequency, every time you turn on an electrical device on the car (headlights, rear screen-demister, brake lights, indicators etc) it makes a farting noise through the stereo which is quite distracting ! It doesn't do it on FM or on the tape player, any ideas guys ? He also wants a cd changer putting in the boot, the head unit has cd capability. Anyone know if the wiring is already there in the boot and what changers they use, I thought it was Alpine. Cheers
Post 114198 by t5tart on 2006-06-05 21:47:41
have u tried an additional supressor
Post 114199 by Tomcat on 2006-06-05 21:48:14
Sounds like he needs a surpressor fitting to cut down on the interference of the cars electrical system. Boot mounted cd changers are not pre wired but being as there's only one lead to run its not a big problem to fit one.
Post 114203 by fraz13 on 2006-06-05 21:50:14
Whats on MW or LW? A didnt think that was even on radios anymore....
Post 114214 by nobananas on 2006-06-05 22:33:58
I thought it sounded like a suppressor problem but the strange thing is it happened suddenly ! Might try and fit an rf choke to the main power lead. May also try the head unit out of my car to eliminate a faulty unit.
Post 114224 by neevo on 2006-06-05 22:50:34
[QUOTE=fraz13]Whats on MW or LW?.[/QUOTE]
Cricket commentary :)
Post 114232 by jim on 2006-06-05 23:02:48
Worth checking aerial ground connection, if these become loose you increase interference signals.
________
Kawasaki ks125
Post 114408 by BlackBeast on 2006-06-06 17:59:39
[QUOTE=jim]Worth checking aerial ground connection, if these become loose you increase interference signals.[/QUOTE]
I was going to say, check all the earth points. Ive got a problem with my radio as in it doesnt work, thats all i have is static, but thats unrelated to this problem.
Post 114480 by mulletboy2 on 2006-06-06 21:02:57
It sounds like an earthing problem. A suppressor will mask the problem (possibly only temporarily), not cure it.. he should really speak to an autoelectrician to trace the problem - could be one of many things, and they'll probably be able to trace and fix the problem pretty cheaply.
Post 114564 by Babybadger on 2006-06-07 10:29:41
[QUOTE=fraz13]Whats on MW or LW? A didnt think that was even on radios anymore....[/QUOTE]
I thought scotland listened to the football on MW/LW?
Post 114565 by Babybadger on 2006-06-07 10:32:12
[QUOTE=nobananas]I thought it sounded like a suppressor problem but the strange thing is it happened suddenly ! Might try and fit an rf choke to the main power lead. May also try the head unit out of my car to eliminate a faulty unit.[/QUOTE]
I get the same on the Sony tape deck in my car, but only when it is on 'accessories' setting on the key. It sounds like the immobiliser (TOADAI606) is interferring every 2 seconds or so. But not when the car is running or just on 'start'.
Post 114566 by fraz13 on 2006-06-07 10:33:01
[QUOTE=Babybadger]I thought scotland listened to the football on MW/LW?[/QUOTE]
A couldnt tell ye man a dont do football.....
Post 114573 by Babybadger on 2006-06-07 11:06:06
[QUOTE=fraz13]A couldnt tell ye man a dont do football.....[/QUOTE]
Neither does the Scottish Football team......LOL
Post 116190 by nobananas on 2006-06-14 20:06:21
Just a quick update on this thread. Had the motor in question in today, pulled out the stereo, checked all the connections, replaced it, fault apparently cured !!! wierd ! I still need to know the make of the cd changer if anyone knows ?
Post 116664 by Babybadger on 2006-06-16 14:38:14
[QUOTE=nobananas]Just a quick update on this thread. Had the motor in question in today, pulled out the stereo, checked all the connections, replaced it, fault apparently cured !!! wierd ! I still need to know the make of the cd changer if anyone knows ?[/QUOTE]
I thought Volvo Cd changers were made by Alpine , and all Alpine cd changers were compatible
Post 116734 by M44K TS on 2006-06-16 17:55:03
this is true, when i was looking for one, only Alpine would be compatible, in the end, i managed to find a used but in good working order oe volvo changer, cost me £61 with the p+p, a fair bit cheaper than the Alpine ones
