Leaking Air Con
Post 107954 by Adge on 2006-05-15 16:30:01
I have a leak of air con. refrigerant, probably up under the dashboard. The air con technician suggested using an air con equivalent of radseal as a first try at sealing the leak. This would save £450! if it worked. Has anyone else tried this route? Seems to make sense and avoid future leaks. Thanks in anticipation. Harry
Post 108013 by blackbooty on 2006-05-15 18:09:07
surely an air con tech would have been able to tell you exactly what the prob is mate. the refrigerant has a dye in it that glows under infered light.... if 20 or so gramms of refrigerant had leaked out there must be traces of it for him to see. i dont know anyone thats used it im afraid. on a side note... where on the white isle are ya ? i grew up in Southampton and spent alot of time the rock. wayne.
Post 108026 by Engineer on 2006-05-15 18:26:02
The stuff works on small leaks. Units fitted to most modern A/C systems are made of chepo alloy and weep for a better word, if they are split badly then forget it, as posted leak detector as in gas will pick up a bad leak and maybe not a small one have another word with your A/C man, older Volvo systems are of a much better quality.
Post 108063 by Adge on 2006-05-15 20:00:28
[QUOTE=blackbooty]surely an air con tech would have been able to tell you exactly what the prob is mate. the refrigerant has a dye in it that glows under infered light.... if 20 or so gramms of refrigerant had leaked out there must be traces of it for him to see. i dont know anyone thats used it im afraid. on a side note... where on the white isle are ya ? i grew up in Southampton and spent alot of time the rock. wayne.[/QUOTE] Thanks for advice. He sways he'll havwe to remove the ghlovebox to be sure . He has put dye in. I too grew up in Southampton. Now at Wootton.
Post 108066 by Adge on 2006-05-15 20:08:33
I just read my last post. Looks as though I've been drinking all day! Sorry, will type more slowly in the future!
Post 108068 by nobananas on 2006-05-15 20:16:21
My 850 also has a leak behind the dash that my air-con bloke found by waving his 'sniffer' round the air-ducts. The leak is most likely the evapourator which looks like a small rad that lives in a very dark place behind the dash. It is not that dear on it's own but the labour to do it is quite high as it's a dash out job. He advised me against using a leak-stop type agent as he claims that it will over time it will damage the rest of the system.
Post 108072 by Adge on 2006-05-15 20:26:39
Thanks "Nobananas", that's complicated what seemed like a simlpe solution. He did say that the compressor might clog if it had to be removed for some reason. It seems exposure to the air on dismantling , which obviously is how the stuff works, can do more harm.
