Volvo Performance Club UK Forums
Go Back   Volvo Performance Club UK Forums > Volvo Forums > General / Off topic Chat
Reply
Thread Tools Display Modes
  (#1) Old
flyingbrick flyingbrick is offline
flyingbrick's Avatar
Talking Actual exchanges between pilots and control towers - Tuesday 28th July 2009, 11:01
Tower: "Delta 351, you have traffic at 10 o'clock, 6 miles!"
Delta 351: "Give us another hint! We have digital watches!"
Tower: "TWA 2341, for noise abatement turn right 45 Degrees."
TWA 2341: "Center, we are at 35,000 feet. How much noise can we make up here?"
Tower: "Sir, have you ever heard the noise a 747 makes when it hits a 727?"
A student became lost during a solo cross-country flight. While attempting to locate the aircraft on radar, ATC asked, "What was your last known position?"
Student: "When I was number one for takeoff."
A DC-10 had come in a little hot and thus had an exceedingly long roll out after touching down.
San Jose Tower Noted: "American 751, make a hard right turn at the end of the runway, if you are able. If you are not able, take the Guadeloupe exit off Highway 101, make a right at the lights and return to the airport."
A Pan Am 727 flight, waiting for start clearance in Munich , overheard the following:
Lufthansa (in German): "Ground, what is our start clearance time?"
Ground (in English): "If you want an answer you must speak in English."
Lufthansa (in English): "I am a German, flying a German airplane, in Germany . Why must I speak English?"
Unknown voice from another plane (in a beautiful British accent): "Because you lost the bloody war!"
Tower: "Eastern 702, cleared for takeoff, contact Departure on frequency 124.7"
Eastern 702: "Tower, Eastern 702 switching to Departure. By the way, after we lifted off we saw some kind of dead animal on the far end of the runway."
Tower: "Continental 635, cleared for takeoff behind Eastern 702, contact Departure on frequency 124.7. Did you copy that report from Eastern 702?"
Continental 635: "Continental 635, cleared for takeoff, roger; and yes, we copied Eastern... We've already notified our caterers."
One day the pilot of a Cherokee 180 was told by the tower to hold short of the active runway while a DC-8 landed... The DC-8 landed, rolled out, turned around, and taxied back past the Cherokee. Some quick-witted comedian in the DC-8 crew got on the radio and said,
"What a cute little plane. Did you make it all by yourself?"
The Cherokee pilot, not about to let the insult go by, came back with a real zinger:
"I made it out of DC-8 parts. Another landing like yours and I'll have enough parts for another one."
The German air controllers at Frankfurt Airport are renowned as a short-tempered lot. They not only expect one to know one's gate parking location, but how to get there without any assistance from them. So it was with some amusement that we (a Pan Am 747) listened to the following exchange between Frankfurt ground control and a British Airways 747, call sign Speedbird 206.
Speedbird 206: " Frankfurt , Speedbird 206! Clear of active runway."
Ground: "Speedbird 206. Taxi to gate Alpha One-Seven."
The BA 747 pulled onto the main taxiway and slowed to a stop.
Ground: "Speedbird, do you not know where you are going?"
Speedbird 206: "Stand by, Ground, I'm looking up our gate location now."
Ground (with quite arrogant impatience): "Speedbird 206, have you not been to Frankfurt before?"
Speedbird 206 (coolly): "Yes, twice in 1944, but it was dark, -- And I didn't land..."
While taxiing at London 'S Airport, the crew of a US Air flight departing for Ft. Lauderdale made a wrong turn and came nose to nose with a United 727.
An irate female ground controller lashed out at the US Air crew, screaming:
"US Air 2771, where the hell are you going? I told you to turn right onto Charlie taxiway! You turned right on Delta! Stop right there. I know it's difficult for you to tell the difference between C and D, but get it right!"
Continuing her rage to the embarrassed crew, she was now shouting hysterically:
"God! Now you've screwed everything up! It'll take forever to sort this out! You stay right there and don't move till I tell you to! You can expect progressive taxi instructions in about half an hour, and I want you to go exactly where I tell you, when I tell you, and how I tell you! You got that, US Air 2771?"
"Yes, ma'am," the humbled crew responded.
Naturally, the ground control communications frequency fell terribly silent after the verbal bashing of US Air 2771. Nobody wanted to chance engaging the irate ground controller in her current state of mind. Tension in every cockpit out around Gatwick was definitely running high.
Just then an unknown pilot broke the silence and keyed his microphone, asking:
"Wasn't I married to you once?"
Cheers Mark..........
EBC DRILLED GROOVED DISCS. EBC GREEN STUFF PADS. AIR CON REMOVED. TWIN EXIT EXHAUST. BLACK MESH GRILLE.GREEN PAPER AIR FILTER. FRONT SPLITTER. POLY TOP BUSH.V70 REAR LAMPS
IT'S HELL TRYING TO GET TO HEAVEN
http://www.r2rc.co.uk/landing/index.htm
The Following 2 Users Say Thank You to flyingbrick For This Useful Post:
DuncVolvoTurbo (Tuesday 28th July 2009), Porcine_Aviator (Tuesday 28th July 2009)
  (#2) Old
Filterlab Filterlab is offline
Filterlab's Avatar
Tuesday 28th July 2009, 11:12
They are classics.
________________________
Cheers, Rob.
  (#3) Old
Porcine_Aviator Porcine_Aviator is offline
Porcine_Aviator's Avatar
Location: Weston on the Mud Somerset or in it if you get the tide wrong.
Tuesday 28th July 2009, 14:50
Thanks Bob.
That will help lighten up the day.
We are getting there - one day my Volvos will work honest
Can you spot P.A. or Mrs P.A.?
Click here to go to our webcam and have a look. luddite.isa-geek.org
All you have to do is put in Guest and vpcuk for the password, and off you go. If you use Firefox click the lower button and then put in the name and password.
Then you can see what the weather is like down in Somerset.
  (#4) Old
Storm-Troll Storm-Troll is offline
Storm-Troll's Avatar
Tuesday 28th July 2009, 15:10
OMG.. thats awsome... u just made me spill me paint on the carpet.. grrrrr lmso....
"Hi, I'm Josef Fritzl, and no Windows was my idea."
  (#5) Old
Gramayr Gramayr is offline
Gramayr's Avatar
Tuesday 28th July 2009, 16:38
Just laughed out loud at the Frankfurt one and got a funny look off the missus.
'97 855 T-5 CD Auto, Emerald Green Metallic, Cream Leather.
  (#6) Old
RobbieH RobbieH is offline
RobbieH's Avatar
Tuesday 28th July 2009, 17:52
A few more along the same vein (I think we've both seen the same) :
From an unknown aircraft waiting in a very long takeoff queue:
'I'm f...ing bored!'
Ground Traffic Control: 'Last aircraft transmitting, identify
yourself immediately!'
Unknown aircraft: 'I said I was f...ing bored, not f...ing stupid!'
O'Hare Approach Control to a 747: 'United 329 heavy, your
traffic is a Fokker, one o'clock, three miles, Eastbound.'
United 329: 'Approach, I've always wanted to say this..I've got the
little Fokker in sight.'
Don't let age define you. It's a number that's all.
  (#7) Old
RobbieH's Avatar
Talking And just to keep the Europeans happy..... - Tuesday 28th July 2009, 17:53
The English are feeling the pinch in relation to recent terrorist threats and have raised their security level from "Miffed" to “Peeved.” Soon, though, security levels may be raised yet again to “Irritated” or even "A Bit Cross". Londoners have not been "A Bit Cross" since the blitz began in 1940 and tea supplies all but ran out. Terrorists have been re-categorized from "Tiresome" to "A Bloody Nuisance". The last time the British issued "A Bloody Nuisance" warning level was during the great fire of 1666.
Also, the French government announced yesterday that it has raised its terror alert level from "Run" to "Hide". The only two higher levels in France are "Collaborate" and "Surrender." The rise was precipitated by a recent fire that destroyed France's white flag factory, effectively paralyzing the country's military capability.
It's not only the English and French who are on a heightened level of alert. Italy has increased the alert level from "Shout loudly and excitedly" to "Elaborate Military Posturing." Two more levels remain: "Ineffective Combat Operations" and "Change Sides."
The Germans also increased their alert state from "Disdainful Arrogance" to "Dress in Uniform and Sing Marching Songs." They also have two higher levels: "Invade a Neighbour" and "Lose".
Belgians, on the other hand, are all on holiday as usual, and the only threat they are worried about is NATO pulling out of Brussels.
The Spanish are all excited to see their new submarines ready to deploy. These beautifully designed subs have glass bottoms so the new Spanish navy can get a really good look at the old Spanish navy.
  (#8) Old
RobbieH's Avatar
And the Aussies have a sense of humor as well......... - Tuesday 28th July 2009, 17:55
After every flight, Qantas pilots fill out a form called a gripe sheet, which conveys to the mechanics problems encountered with the aircraft during the flight that need repair or correction. The mechanics read and correct the problem, and then respond in writing on the lower half of the form what remedial action was taken, and the pilot reviews the gripe sheets before the next flight.
Never let it be said that ground crews and engineers lack a sense of humour.
Here are some actual logged maintenance complaints and problems as submitted by Qantas pilots and the solution recorded by maintenance engineers.
(P = The problem logged by the pilot.)
(S = The solution and action taken by the mechanics.)
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except auto-land very rough.
S: Auto-land not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're there for.
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
P: Noise coming from under instrument panel. Sounds like a midget pounding on
something with a hammer.
S: Took hammer away from midget.
  (#9) Old
AlanG AlanG is offline
Banned
Location: In the Scottish boonies,at the bottom of a pint tumbler..
Send a message via MSN to AlanG
Wednesday 29th July 2009, 13:54
Brilliant stuff.........
  (#10) Old
Wibren V70R Wibren V70R is offline
Member
Wibren V70R's Avatar
Wednesday 29th July 2009, 15:40
Quote:
+1 Excellent stuff
  (#11) Old
p fandango p fandango is offline
p fandango's Avatar
Wednesday 29th July 2009, 15:48
sat at the end of Cov runway waiting for my mate to land & one of the other planes in the area asked if he could do a low level pass & if the tower could tell him if his wheels were down or not
  (#12) Old
Gramayr's Avatar
Wednesday 29th July 2009, 18:13
A mate told me a true story..
A chap was out flying his plane for most of the morning, doing stunts etc. After he landed he got in his car and accelerated hard towards a hedge - then tried to pull back on the steering wheel!
  (#13) Old
j@mie j@mie is offline
Member
j@mie's Avatar
Send a message via MSN to j@mie
Wednesday 29th July 2009, 20:55
fantastic!!!
Volvo V50 T5 R-DESIGN SE Sport (Titanium Grey) 2007
BSR PPC Stage 1 (263bhp - 332lbs/ft) + JR Performance Panel Air Filter
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vBulletin
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Hosted by Xengo, a UK web hosting company.
vpcuk.org: A discussion forum for performance Volvo owners and enthusiasts.
