Junior Member
My 850... -
Wednesday 31st December 2008, 16:12
Hey everyone, i'm just posting this up because i need a place for it...
They're plans for my car [1995 Volvo 850 SE Estate (2.0 FWD Auto)]
Details (stock)–
Manufacture: Volvo
Model: 850
Trim: SE
Colour: Metallic Blue
Body Style: Estate
Doors: 4 + boot
Licence plate: M416SUD
VIN Code: -
Year: 1995
Mileage Bought: 98000 miles
Money Bought: £995
Date bought: August 2007
Air Conditioning: Yes
Catalytic Converter: Yes
Running temp norm.: 90∘C
Average MPG: 28mpg
Seatbelt Pre-tensioners: Yes
Airbags: 2
Seats: 5
Stereo : Cassette AM/FM Radio
Options:
• Heated Front Seats
• Electric Front Windows
• Electric Mirrors
• Heated Rear Window
• Electric Sunroof
• Central Locking
• Immobiliser
Engine (Stock) –
Code: B5204S 20v
Aspiration: Naturally Aspirated
Capacity: 1984cc
Power: 143bhp @ 6500rpm
Torque: 129ft/lbs @ 3800rpm
Layout: Inline 5 cylinder
Bore x Stroke: 81x77mm
Compression Ratio: 10.3:1
Valves: 20
Fuel: Petrol (91-95 unleaded)
Fuel Delivery: LH-Jetronic 3.2
Position: Front/Transverse
Redline: 6800rpm
Idle: 850rpm
0-60mph: 10.6 Seconds
Top Speed: 124mph
Drive (stock) –
Transmission: Automatic (Economy, sport, winter modes)
Gears: 4 Speeds + Overdrive
Final Drive: 3.16:1
Drive : Front Wheel Drive
Dimensions (stock) –
Length: 4710mm
Width: 1760mm
Height: 1440mm
Wheelbase: 2660mm
Front Track: 1520mm
Rear Track: 1470mm
Front Wheels: 190/50 R15
Rear Wheels: 190/50 R15
Capacities (stock) –
Fuel Tank: 73 Litres / 16 Gallons
Cooling system: 7.2 Litres
Engine oil: 5.3 Litres
Gearbox oil: 7.6 Litres
Power Steering Fluid: 800cc
Washer Reservoir: 4.5 Litres
Suspension (stock) –
Front Suspension:
• Type: Independent
• Toe-in: 0.33∘ - 0.1∘
• Camber: 0∘ - 1.0∘
Rear Suspension:
• Type: Independent
• Toe-in: 0.07∘ - 0.18∘
• Camber: -1∘ - 0.5∘
Brakes (stock) –
Front Brakes:
• Type: Ventilated Disk
• Calliper Pistons: 2 (1x1)
Rear Brakes:
Modifications –
1- Pioneer CD Player AM/FM Radio [9/07]
2- Replaced Rear Dampers [10/07]
3- Replaced Left Front Brake Calliper [4/08]
And now... For what i plan :
Engine -
Jetex 2.5" CAT back system with 100mm single Round tailpipe
JR Performance Air Filter
Pipercross Blue Cold Air Feed
Suspension -
Kilen Sports Lowering Springs
Uprated Anti-Roll Bar Kit
Volvo Aluminium Strut Brace -Right Hand Drive Only
Exterior -
No link, but I'm removing the wheel trim
Black & Mesh Grille
VOLVO 850 LATE MODEL front spoiler
Volvo V70 Roof Spoiler - Speed
Classic Plate Design
Ripspeed Dome Valve Caps, Blue
Interior/Electronics -
CB 27 MHz AM/FM Mobile Transceiver
1/4 Wave Whip Antenna
Pioneer DEH-3000MP CD Tuner
Vibe SLR12 - 12'' Car Passive Subwoofer
OMP Bucket Seat Design 2
OMP Seat Runners
Wednesday 31st December 2008, 17:01
Plenty of tweaking you have planned
Gun metal grey - Volvo 850 R - Saloon
Really Impressive Completely Aggressive - Just how every T5/R should be
Member
Wednesday 31st December 2008, 17:06
that DTM front splitter isnt gonna fit your car
Junior Member
Wednesday 31st December 2008, 17:11
Quote:
It isnt? Its meant for 1993 > 1996 Volvo 850's...?
Wednesday 31st December 2008, 17:17
that splitter is similar to mine,i had the option ot that 1 & the one iv got fitted...
diffrence was the mesh slit in it...
should bolt up to the bumpe same as mine im guessing.
Wednesday 31st December 2008, 17:20
Wednesday 31st December 2008, 17:23
Quote:
Originally Posted by p fandango
yeah thats mine....i didnt pay that for it tho lol.
Junior Member
Wednesday 31st December 2008, 17:27
Hmm, looks a fair bit better too, looks more OEM than a bold on job, Nice one! cheers
Wednesday 31st December 2008, 17:36
hello mate nice car. good luck with the mods. you are not to far from me. im just down the road in dunstable
Wednesday 31st December 2008, 17:53
there it is fitted
Junior Member
Wednesday 31st December 2008, 17:55
looks great Stealth (nice heads too), i guess I'm gonna go with that instead then
Wednesday 31st December 2008, 17:58
cheers,
they r standard headlights..........
i just painted the outer lense that isnt used then fitted lense covers which i tinted before i fitted so it protects the paint & it dont flake of,
Wednesday 31st December 2008, 20:50
Looks more like a genuine Volvo accessory from the picture, quite close to the style of the R front bumper
Wednesday 31st December 2008, 20:51
Quote:
Originally Posted by t5 stealth
there it is fitted
Got any closer shots of the headlights ?
Wednesday 31st December 2008, 21:00
ok see if this works lol
Wednesday 31st December 2008, 21:03
Cheers, makes a hell of a difference to the look of the front of the car, do you think that could be done for more permant effect by removing the glass from the headlight and actually painting the reflector itself??
Wednesday 31st December 2008, 21:09
i dont think it would work as the pattern is produced by the glass & not the reflector,
the out side of the lense isnt used for the pattern,if you look close at the glass its actually got the sort of circle around it,the light is thrown through the centre part of the glass,i just painted it to see if it would work & it did,doesnt affect the beam either as i checked it with a beam tester...
the lense covers are from volvo,i just used that spray tint on the inside of the covers then it dont get a hammering from the weather,stones etc..
i only did it cos i was gona get those after market 4 headlights but they look a bit cheap & not very well put together so i didnt bother......
if it didnt work i could use a stanley blade to remove it lol.....
Banned
Thursday 1st January 2009, 00:14
seems a bit excessive to me for whats a bottom of the range model, get a T5!! :p lol
Thursday 1st January 2009, 00:26
and im the one that gets stick off people for a couple of stickers LOL
sorry it looks odd to me.
Thursday 1st January 2009, 02:07
I got to agree with you there dude lol. But yours is still a rare colour.
MartynV70R - Be Prepared
2008 08 C70 T5 SE Lux Premium - Inscription Ember Black pearl
1998 R V70R - Saffron
2003 53 V40 1.9D Sport - Silver Green metallic
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
vpcuk.org: A discussion forum for performance Volvo owners and enthusiasts.
