Volvo Performance Club UK Forums
Go Back   Volvo Performance Club UK Forums > Volvo Forums > Modifications and tuning
Reply
Thread Tools Display Modes
  (#1) Old
Murphy Murphy is offline
Murphy's Avatar
Turbo torque - Thursday 11th November 2004, 15:19
Ready to get confussed ???
Click the image to open in full size.
This is a picture of a 20g Mitsubishi turbo, specifically a Mitsubishi TD06-20G Turbo. Now up until around 10 mins ago i thought the line up of turbo's produced by mitsubishi were as follows. 15g 16T 18T and 19T. Now this has thrown me, and i have had a bit of an explanation but nothing that really helps me to understand. Per G or T of Mitsubishi turbo's there are different models also like the 20g has a smaller brother called the Mitsubishi TD05-20G Turbo.
i could go on with models and varients - but if anyone knows anymore ?!?!
Current daily hack: 2008 Suzuki GS500f
  (#2) Old
Murphy's Avatar
Friday 12th November 2004, 14:13
Strange that not 1 person knows anything about Mitsubishi turbos
  (#3) Old
Pedro Fandango
Guest
Posts: n/a
Friday 12th November 2004, 14:25
i've never looking into changing mine
  (#4) Old
Bracer Bracer is offline
Send a message via MSN to Bracer
Friday 10th December 2004, 07:56
Super 20G
Model: TDO6H-20G-TDO5H-10CM2
Maximum HP Capacity: 500
Optimal HP Range: 300-450 HP
Mounting (turbine inlet)*: T3 style
Exhaust (turbine outlet)*: 3-bolt flange, part number H TZ-7180
Compressor Inlet: accepts 2 ˝” hose
Compressor Outlet: accepts 2” hose
Oil Inlet*: 12 x 1.5mm straight thread
Oil Outlet*: 2-bolt flange, part number H TZ-7190
Optional water-cooling ports: included
Super 20G is a ‘hybrid’, similar in concept to the T3-T4 but vastly superior for street use due to its modern and efficient design. We use a TDO5H-10cm2 turbine section mated to a TDO6H-20G compressor. The result is a unit that will support up to 500HP, yet delivers the best low-speed street characteristics available for such power capability. Like the Super 16G, it’s also a good choice for stock engines that will be upgraded internally later, as it can be run at low boost levels safe for a stock engine (typically 5-8 PSI), then turned up later after you improve the engine’s internals. The internal wastegate is super-effective, and can be ordered with your choice of adjustable wastegate actuators (click here). These actuators are also available separately should you decide to change boost levels in the future.
SAM ECU
Custom Super 60 18T Turbo With Uprated 300/70 W/G
Blitz Dual SBC Boost Controller
Blue Injectors
NGK Iridium Spark Plugs
Custom 1 Box 3" Turbo-Back Exhaust
TurboXS Type R-HFL
K&N Style Cone Filter With Cold Feed
87 Deg Stat
Full Poly Bushed
Custom 60mm Drop Suspension
Strut Brace
18" Shadow Chrome Pegs
305mm Drilled Brembo's With Ferodo DS Pads
6000k HID Kit
Flat Areo Style Wipers
See All The Pics Of SAM Here
  (#5) Old
Mrsmopp Mrsmopp is offline
Member
Mrsmopp's Avatar
Friday 10th December 2004, 08:40
Bracer babe - can you make your pics a little smaller??
x
  (#6) Old
Friday 10th December 2004, 08:42
I thought you always said "Bigger the Better"
SAM ECU
Blue Injectors
TurboXS Type R-HFL
87 Deg Stat
Full Poly Bushed
Strut Brace
6000k HID Kit
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vBulletin
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Hosted by Xengo, a UK web hosting company.
vpcuk.org: A discussion forum for performance Volvo owners and enthusiasts.
