Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Member
    Mar 2012
    Fife
    20
    Auto box................ HELP!!! 1999 V70R
    Hi all, so I took the car and flushed and changed the auto box fluid with Volvo stuff, now I have no 3rd gear!!!
    It's really smooth going from 1st to 2nd, but there's no third at all.
    All that was done was a flush, what the hell could have happened??
    Is there likely to be an easy fix?
    Mine is the 5 speed auto.
    5 pot heart of a Volvo
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    oh dear this is the problematic box when it goes wrong, feel for you mate, you wont find another if you need to, maybe time for a manual conversion?
    Beer Baron
    LiamT4's Avatar
    Jan 2010
    Leicester
    1,849
    Not many people who have experience with your auto. Are you sure you used the fluid for the 5spd and not the 4spd?
  4. The Following User Says Thank You to LiamT4 For This Useful Post:
    merc85 (Tuesday 27th March 2012)
  5. #4
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    Double check the correct fluid was used and also check the level of the fluid
  6. #5
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    Also after you changed the fluid, before driving did you select all the gears a few times with the car stationary 1st?
    As this gets the whole system bled up correctly, then check the level, drive easy for 10 - 15 mins check and add if req any of the correct fluid.
  7. The Following User Says Thank You to merc85 For This Useful Post:
    Stuartieboy (Tuesday 27th March 2012)
  8. #6
    Member
    Mar 2012
    Fife
    20
    Yep, did all that. The fluid is Volvo stuff for the 5 speed box. I have run the car stationary, had the car on a ramp and gone through the gears too. Occasionally it seemed as if the car hit fourth when it was on the ramp when it was coming back down the revs, but not all the time.
  9. #7
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    Unhappy
    Trouble is doing a auto fluid change is always a cross fingers job, It can disturb alot of rubbish floating about in the box, But if you dont change the fluid obviously it will also lead to damage.
    What colour was the old fluid when it came out?
    Chances are that the car had may have had a issue before you bought it i'd expect.
  10. #8
    Beer Baron
    LiamT4's Avatar
    Jan 2010
    Leicester
    1,849
    Automatics are a very complex bit of kit so when they do go wrong it can be difficult to fix them. Not many places specialise in them and even places that do, only seem to do certain boxs.
    unfortunatly.
  11. #9
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Post auto gear box
    Hi just looking at your problem is the auto box the same as the ones fitted to the 2003 on s60s ,As there is a large nut shaped fitting at the top of the box which which looks like a oil filler but if this is removed you will lose 3rd gear as this fitting holds the drive band for 3rd gear.
    Did a workshop change the oil for you ?,just ask them where the put the oil in it.
    you google this problem there is a way to repair the box with out a full rebuild.
    This is my first reply on this site hope this might help.
    Harvey
  12. The Following 8 Users Say Thank You to Harvey For This Useful Post:
    Chad (Thursday 29th March 2012),Gunscrossed (Wednesday 28th March 2012),M-R-P (Wednesday 28th March 2012),mitchyboy01 (Sunday 1st April 2012),muscas (Saturday 31st March 2012),Stuartieboy (Tuesday 27th March 2012),t5steve (Tuesday 27th March 2012),volvokid (Wednesday 28th March 2012)
  13. #10
    Gizza job!
    Yosser's Avatar
    Jul 2008
    The 1980's
    161
    I've read about that problem on the XC forums - http://volvoxc.com/forums/showthread.php?t=15297
    No idea if it's the same box (or similar).
  14. The Following User Says Thank You to Yosser For This Useful Post:
    Stuartieboy (Wednesday 28th March 2012)
  15. #11
    Member
    Mar 2012
    Fife
    20
    Harvey
    Harvey, you may just be a genius!
    That is exactly where the garage filled the gearbox!
    That would explain everything. They're looking into it now. Thanks for the info!
  16. #12
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    Hope you can get it sorted fairly painlessly
  17. The Following User Says Thank You to Volvostorm For This Useful Post:
  18. #13
    Member
    Mar 2012
    Fife
    20
    All is well in Volvoland!!!
    Harvey, you were bang on the money!
    Spoke to my mechie this morning and he's fixed it!!
    Apparently he took out the B4 servo and some 'things', performed a bit of jiggery-pokery and contortionism, and got it all hooked back up! I haven't driven it, and I'm away for a fortnight so I can't but he assures me he's been up and down the gears on a run and it's silky smooth! Happy days!!
    I wonder how many working boxes and cars have been scrapped because of this????
    Last edited by Stuartieboy; Wednesday 28th March 2012 at 12:34. Reason: Poor spelling (too excited!!)
  19. The Following 3 Users Say Thank You to Stuartieboy For This Useful Post:
    merc85 (Sunday 1st April 2012),MoleT-5R (Sunday 2nd December 2012),muscas (Saturday 31st March 2012)
  20. #14
    Gunscrossed's Avatar
    Mar 2012
    Essex
    65
    Harvey
    What a good first post!
  21. The Following 2 Users Say Thank You to Gunscrossed For This Useful Post:
    Chad (Thursday 29th March 2012),martybelfastt5 (Saturday 31st March 2012)
  22. #15
    Member
    Mar 2012
    Fife
    20
    Quote Originally Posted by Gunscrossed View Post
    Couldn't agree more!!!
    Thanks again for the help!!
  23. #16
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    I wonder if we'll see him again or is he a Batman type, lurking in the background with a pocket full of incredibly useful info, ready to appear and surprise us all
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  24. #17
    Member
    Mar 2012
    Fife
    20
    Quote Originally Posted by martinrpeachey View Post
    We'll need to get a special floodlight with a Harvey symbol on it to call him, just in case he isn't online!
  25. #18
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    well done mate happy for you
  26. #19
    Feb 2006
    manchester
    628
    good result
  27. #20
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Hi great news that you got it fixed so fast but best of all for free.
    Must thanks for your other comments
    Harvey
