Anyone had any dealings with the Air bag light on. what does it normally mean if the lamp is on??????
Means a fault or has a bad earth on the wiring.Originally Posted by CAMO
I think it is B5 is the fly lead socket you need to connect to and you should come up with a code unless it is an OBD11 system (1995 onwards). (look under the bonnet next to the steering pump found here http://www.volvospeed.com/CheckEngine.php)
http://experts.about.com/q/Volvo-Rep...-srs-light.htm has the codes.
