Results 1 to 4 of 4
    Shiny Superstar
    Back in the game!
    Wobbly Dave's Avatar
    Aug 2004
    Stunning Shropshire
    2,501
    Additional Engine Oil Cooler - good or bad idea?
    I have talked at great length to Hamish about this. Everyone knows that the most wear occurs when engine oil is cold - i.e. first start in the morning.
    I am concerned that by developing an additional cooler this will prolong this period and rather than protecting, will actually cause more damage, particularly if you do short runs.
    On the flipside if you plan to run the car on track days often then it is likely to be a good idea.
    I think and I concur with Hamish on this that the use and regular change of quality oils will prevent high temp degradation, which is the purpose of the cooler to start with.
    Volvo ABS ECU Repair
    Pedro Fandango
    Guest
    i had to replace my rad because the standard oil cooler failed but that was more to wear & tear than because it couldn't cope, plenty of 850's last thousands of miles using the standard one so why mess (& you'll only end up blocking air to the IC)
    Aug 2004
    Braintree, Essex
    0
    Quote Originally Posted by Pedro Fandango
    I think the positioning of the additional cooler would be best situated behind the drivers side lower air intake
    SAM ECU
    Custom Super 60 18T Turbo With Uprated 300/70 W/G
    Blitz Dual SBC Boost Controller
    Blue Injectors
    NGK Iridium Spark Plugs
    Custom 1 Box 3" Turbo-Back Exhaust
    TurboXS Type R-HFL
    K&N Style Cone Filter With Cold Feed
    87 Deg Stat
    Full Poly Bushed
    Custom 60mm Drop Suspension
    Strut Brace
    18" Shadow Chrome Pegs
    305mm Drilled Brembo's With Ferodo DS Pads
    6000k HID Kit
    Flat Areo Style Wipers
    See All The Pics Of SAM Here
    Volvo sucks....... lots of air
    glock19's Avatar
    Feb 2005
    8
    Quote Originally Posted by Bracer
    I concur. A few of my local guys here has done it for the ATF. As for the additional cooler for the engine oil, can you not have a valve to bypass it for non-track/hard use ? It could be temp controlled.
