[B]Help I have a problem with my 850,somtimes when turning my engine on the ABS light stays on & no electics work,If you turn the key a fraction back the abs light goes out & eletrics are then ok,I did squrt some wd40 in & around the barrel & seemed to solve the problem for a couple of months,its just starting to do it again & spraying wd40 is a short term solution & I really need to sort it out, I think the barral or the key is worn but which one,I only ever had one key with the car so is it possable keys can wear out?,has anyone else had this problem as a replacment key can be pricey from a volvo dealer & been told there lazer cut !
Cheers 850south[/B]
