Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    nikgallagher's Avatar
    Jan 2005
    Sutton
    0
    Lambda Light Again!!
    I recently had the lambda light come on (96 854), because - I thought - that the thermostat needed changing and it had been running rich for a couple of weeks. Changed the thermostat and engine is running at proper temp all the time now, so got the code read (2-3-2) and deleted so the light went out. Happy Nik again. However, this morning approx 50 miles after the light was reset, it came on again!! Any ideas gratefully welcomed, and does anyone know what the code 2-3-2 actually stands for?
    Aug 2004
    Braintree, Essex
    0
    2-3-2 Lambda adjustment; For 1994 and later, adaptive heated oxygen sensor control / long term fuel mixture too weak at idle
    Sound like you need check out your fuel and ignition system.
    SAM ECU
    Custom Super 60 18T Turbo With Uprated 300/70 W/G
    Blitz Dual SBC Boost Controller
    Blue Injectors
    NGK Iridium Spark Plugs
    Custom 1 Box 3" Turbo-Back Exhaust
    TurboXS Type R-HFL
    K&N Style Cone Filter With Cold Feed
    87 Deg Stat
    Full Poly Bushed
    Custom 60mm Drop Suspension
    Strut Brace
    18" Shadow Chrome Pegs
    305mm Drilled Brembo's With Ferodo DS Pads
    6000k HID Kit
    Flat Areo Style Wipers
    See All The Pics Of SAM Here
    Jan 2005
    Sutton
    0
    Hmmm. Sounds expensive. Looks like the heated sensor is just an unplug, unscrew and replace job. Would it be worth doing this as a first stab? Have seen from previous posts that the sensor itself is quite expensive though.
    Justin's Avatar
    Aug 2004
    Midlands UK
    374
    232 is long term fuel trim as bracer said, it will 99% of the time be caused by a vacume leak, check the elbow that goes into the left of the manifold, (if yours has one), if not it will be a vac hose sucking or blowing air thats giving the ecu the wrong signals from un metered air, hence causing the fault code because its supplying to much or to little fuel.
    Check your hoses
    <a href="<a href=http://s65.photobucket.com/albums/h225/RobertBingley/Misc/?action=view&current=Animation1.gif target=_blank>http://s65.photobucket.com/albums/h2...Animation1.gif</a>" target="_blank"><img src="<a href=http://i65.photobucket.com/albums/h225/RobertBingley/Misc/Animation1.gif target=_blank>http://i65.photobucket.com/albums/h2...Animation1.gif</a>" border="0" alt="Photobucket"></a>
  5. #5
    Jan 2005
    Sutton
    0
    Thanks for the info. I will have a look at all the hoses around the intake manifold. Has always made a whooshing sound on accelerating (during nat asp running) but I thought that was just an auto thing. Just seems strange that it has happened exactly the same time as changing the thermostat.
  6. #6
    siamblue's Avatar
    Nov 2004
    Ilford,Essex.
    747
    Quote Originally Posted by nikgallagher
    If it happened at the same time it must be in what ever you moved,
    Do the 850s have 2 Vacuum elbows like the S/V70s ?
  7. #7
    Jan 2005
    Sutton
    0
    I did change the air filter at the same time as the thermostat. Could the problem be coming from there? Didn't have to disconnect any hoses in either case though.
  8. #8
    Aug 2004
    Braintree, Essex
    0
    See here
    SAM ECU
    Blue Injectors
    TurboXS Type R-HFL
    87 Deg Stat
    Full Poly Bushed
    Strut Brace
    6000k HID Kit
  9. #9
    Jan 2005
    Sutton
    0
    Now there's an answer! I bow in the presence of your greatness.
  10. #10
    Jan 2005
    Sutton
    0
    Have just been out to check the vac hoses and sure enough the hose elbow leading in to the manifold has perished and broken away from its mounting.
    I can't thank you knowledgable people enough. To have such a wealth of experience on hand must be saving all us pilgrims thousands of pounds each year on head-scratching Volvo garage estimates. Keep up the good work, and another thousand thanks for the pearls of wisdom you have shared with me.
  11. #11
    Aug 2004
    Braintree, Essex
    0
    Your welcome, always glad to help
    SAM ECU
    Blue Injectors
    TurboXS Type R-HFL
    87 Deg Stat
    Full Poly Bushed
    Strut Brace
    6000k HID Kit
  12. #12
    Justin's Avatar
    Aug 2004
    Midlands UK
    374
    That will 100% be the cause then mate.
    20 minute job, ive done 6 of them now so a dab hand......curved bottle nose pliers, long screwdriver and a scratched had, you will be ok
  13. #13
    Aug 2004
    Braintree, Essex
    0
    Quote Originally Posted by Justin
    You do realise you going to be asked to make that 7 now dont you
    SAM ECU
    Blue Injectors
    TurboXS Type R-HFL
    87 Deg Stat
    Full Poly Bushed
    Strut Brace
    6000k HID Kit
  14. #14
    Shiny Superstar
    Back in the game!
    Wobbly Dave's Avatar
    Aug 2004
    Stunning Shropshire
    2,501
    A bit of elbow grease never did anyone any harm
    I'll get my coat
    Volvo ABS ECU Repair
  15. #15
    Aug 2004
    Braintree, Essex
    0
    Quote Originally Posted by dave850R
    I'll get my coat
    I've never minded greasing myself up to the elbo for someone else
    SAM ECU
    Blue Injectors
    TurboXS Type R-HFL
    87 Deg Stat
    Full Poly Bushed
    Strut Brace
    6000k HID Kit
  16. #16
    Member
    Aug 2004
    73
    Where is that pukey smiley!!!!
    x
  17. #17
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    Did no-one get my joke about the elbow or was it just not funny
    BTW - The idea of Steve getting slimed up for action had me worried too!
  18. #18
    Member
    Aug 2004
    73
    The latter LOL!!! Just kidding!!
    x
  19. #19
    Aug 2004
    Braintree, Essex
    0
    The joke No it just weren't funny
    And worried, you should be
    SAM ECU
    Blue Injectors
    TurboXS Type R-HFL
    87 Deg Stat
    Full Poly Bushed
    Strut Brace
    6000k HID Kit
  20. #20
    Jan 2005
    Sutton
    0
    Did you have to take the power steering pump off to get access to the clamp on the manifold? Seems quite tucked away, even with curved pliers. Also, where does the other end of the hose go? Thought it would go straight to the ECU but seems to disappear in to the bowels of the engine.
