going to veiw 2001 d5 tomorrow,what should i be looking for and when does cam belt require change for this model??,its done 120,000 miles, any help would be appreciated richard buzzin so dont be cruel lol
96k cambelt =make sure its cold when you first start it to see if it idles okay and revs smoothly as d5s have a injector problem on high milers.make sure central locking works properly on all doors/boot as this is a common fault also.Originally Posted by jimmyc
with it running pull out dipstick a inch or two and feel round the gap for backpressure(they should be no wind coming out of the dipstick tube).if there is the rings are worn.
other than that just a general inspection,good luck
PHASE 2 S40 T4
S60 D5 :
2002 S60 2.4T
OCTAVIA VRS
2006 S40 SPORT SE
Also, make sure it fires up quickly even when cold. If it takes ages to fire up, then it needs a set of injectors.
Adam.
many injector problems due to wrong fuel in earlier use, also possible issue with earlier filters i believe.
now : 850 2.5 auto
Ex : T4 with NOS on board
cheers guys thats really appreciated richard
purchased it and checked all you advised, cheers richard
Has anyone any more comments on looking at a V70 D5, i have heard of gearbox issues and front suspension / steering / bush issues ?!!?
My TWITTER username
not heard about gearbox faults on manuals but they do sometimes suffer from front wishbone bushes do to the front end weight really more than anything but not to bad a job to doOriginally Posted by Murphy
SIGNATURE COURTESY OF STORM TROLL
