sounds like a planOriginally Posted by Andy
if u need the codes scanning in i can do that
or at least a jpeg image any how
mindu could probably c+p fron that program to a word doc ....not sure
maybe volvospeed already has a thread ??
1995 854 t5
40mm lowered
bilstien shocks
strut brace [ome] wow what a difference
poly top mount
new turbo
drop links and rod ends
bonnet wadding removed
RICA power
turob to i/c pipe hose
bcs hoses
silicone vac lines (part done)
new oe wishbones
k&n panel filter
to do
paint up v70 r calipers calipers
R bumper
my vBGarage
T5start you are a star mate, many thanks, needs to be a sticky this how too just incase some else doesn't know what to do,
Gary.
Deffo Sticky... But not this thread, i'll sort a proper (neater) one out soon.
lol i know how much volvo charge to reset the service light and its so damn simple on these
that would be another good how to if its no there
£40 to plug in a flu lead and press a button lol
1995 854 t5
40mm lowered
bilstien shocks
poly top mount
new turbo
RICA power
bcs hoses
new oe wishbones
k&n panel filter
to do
R bumper
my vBGarage
Ok Chaps, Now got the codes read.... thanks again to t5tart
1-2-1 is the only code showing
MAP sensor signal faulty or not present
1995 854 t5
40mm lowered
bilstien shocks
poly top mount
new turbo
RICA power
bcs hoses
new oe wishbones
k&n panel filter
to do
R bumper
my vBGarage
just found this link which is excellent and will be used as part of the how to.... what you think?
I take it that as the MAF is showing faulty that could be the cause of my erratic / hesitating acceleration?
Excellent work so far
yer haynes call it a MAP sensor though lol
1995 854 t5
40mm lowered
bilstien shocks
poly top mount
new turbo
RICA power
bcs hoses
new oe wishbones
k&n panel filter
to do
R bumper
my vBGarage
In fact, instead of re doing a how to that link i've just posted is a how to... doh!!
how come i couldn't find that!!! grrr
not a clue
but 1-2-1 on the MAP manifold absoloute pressure not MAF ..........
accordint to mr haynes
MAP sensor
instead of MAF sensor the fenix system uses a MAP sensor abd air inle temp sensor
the calculate the volume of air drawn in
MAP sensor is conected to the inlet manifold via a hose and uses a piezo-electrical cryastal to convert manifold pressure to an electrical signal tobe sent to the ecu
does this make sense to anyone lol
1995 854 t5
40mm lowered
bilstien shocks
poly top mount
new turbo
RICA power
bcs hoses
new oe wishbones
k&n panel filter
to do
R bumper
my vBGarage
What list you looking at to get that code?Originally Posted by t5tart
It's definately relating to MAF on the 850 T5.
Adam.
haynes manual and the codes in the thread clicky you posted
MAP sensor
1995 854 t5
40mm lowered
bilstien shocks
poly top mount
new turbo
RICA power
bcs hoses
new oe wishbones
k&n panel filter
to do
R bumper
my vBGarage
read on more its the fenix 5.2 system which is used on 10v non turbo engines
1995 854 t5
40mm lowered
bilstien shocks
poly top mount
new turbo
RICA power
bcs hoses
new oe wishbones
k&n panel filter
to do
R bumper
my vBGarage
Was just gonna say mate... MAP relates to the 10V engine!!!
Stop confusing everyone!!! heheh
Thanks AdamOriginally Posted by volvotuning
hehehehehehe
im confused myself haha its not hard
1995 854 t5
40mm lowered
bilstien shocks
poly top mount
new turbo
RICA power
bcs hoses
new oe wishbones
k&n panel filter
to do
R bumper
my vBGarage
B4 you go replacing the MAF sensor make sure you check ALL the vacuum line, inc that pig of one between intake manifolds left hand side. You can get to it without removing intake manifold. It's a bitch to get to. It will through a light and cause 1-2-1 code because it's all related. 9 times out of 10 it will always be something that causes something else to throw up the light.. ie vacuum elbows dont have sensors attached to them...know what i meanOriginally Posted by t5tart
I know this cos same code and light last year for me.
http://www.volvoclub.org.uk/850_70_fault_codes.shtmlOriginally Posted by Andy
and for engine bits http://au.geocities.com/ozbrick850/c...odesvolvo.html
Make sure you get ALL the codes that show up. make sure there is no other code after 1-2-1
Originally Posted by LeeT5
if his engine a 1994 like mint the vac lines wont run to the left og the intake manifild that nipple is blocked off
it runs over the head behind the spark plug cover and to the tree
1995 854 t5
40mm lowered
bilstien shocks
poly top mount
new turbo
RICA power
bcs hoses
new oe wishbones
k&n panel filter
to do
R bumper
my vBGarage
