i have just fitted a manual boost controller and want to know what boost setting my 1995 T5 will run at comfortably, using this vehicle each day.
thanks
neil
thanks
neil
Morning Neil.
The stock ECU will allow boost to be increased up to 1.0 Bar (14.5 Psi) before it senses "Over-Boost" and cuts the ignition.
I assume you have fitted / plan to use a calibrated boost gauge to tune the boost as this is really a MUST !
You MUST ensure you keep MAX boost / and Spikes below the above figure especially when rev's are below 3000 rpms other wise you risk bending a con rod.
Steve
SAM ECU
Custom Super 60 18T Turbo With Uprated 300/70 W/G
Blitz Dual SBC Boost Controller
Blue Injectors
NGK Iridium Spark Plugs
Custom 1 Box 3" Turbo-Back Exhaust
TurboXS Type R-HFL
K&N Style Cone Filter With Cold Feed
87 Deg Stat
Full Poly Bushed
Custom 60mm Drop Suspension
Strut Brace
18" Shadow Chrome Pegs
305mm Drilled Brembo's With Ferodo DS Pads
6000k HID Kit
Flat Areo Style Wipers
See All The Pics Of SAM Here
