Can anyone please tell me what my body colour is called?
Thanks.
Thanks.
Shiney,
Haven't got a clue. If no one else knows you should be able to get the paint code from the ID plate in the engine bay. Inside of the NSF wing if I recall correctly.
Post the paint code up and someone should be able to look it up for you.
Regards
Andy
Thanks Andy, I'll look it up in my lunch break.
No worries. When you fond the ID plate you'll see it's got two columns and six rows. The paint code should be in the right hand column, third row down.
I think the paint code should be three digits. Post what it is and I'll try and find out the colour if no-one else has it.
Regards
Andy
i'll go for regent red pearl
now : 850 2.5 auto
Ex : T4 with NOS on board
Red
Sicknote
1997 S40 1.8i "Rakel"
RUBBISH! It's clearly Nautic Blue Pearl! LOL.Originally Posted by madness
You're probably right. It's otherwise know as simply Pearl Red.
I've found some paint codes. 414 is Ruby Red, 418 is Pearl Red or Regent Red Metallic and 428 is Coral Red Metallic.
I think Coral Red Metallic is slightly lighter than Shiney's car. There's a V70 T5 parked over the road from my office which is paler than Shiney's which I'd guess is Coral.
Regards
Andy
Andy
Re load your avatar. Some months ago there was a problem and they got screwed up. Reloading should sort it.
Don't know what colour it is but looks good
Martin
"Experience is something you don't get until just after you need it"
855
280 RICA
ITG Panel filter
Volvo strut brace
I know this sounds silly but I had a funny feeling it was called something like autumn gold.....almost certain it had gold in the title?
Yes I know, its on a red / burgundy cloured car.
Just need to know the colour for getting some made up into a touch up paint.
definetly regent red pearl, had a 95 850glt estate in this colour.
That's colour code 418 then.
Halfrauds do a touch up kit for around a tener which is actually quite good.
Regards
Andy
My paint code is '441'. Cosmic blue - (AKA) Laser blue.
Same colour as mine! mmmmmm nice....... thats 418 (Turbo red metallic)
J5
It's a ROCKET PROPELLED ARMCHAIR, and I LOVE IT
Current mods :ZTRONS cd/dvd touchscreen headunit, Clear side repeaters, Zenon effect headlamp bulbs, Equus turbo boost guage, Front strut brace, R-SPEC MBC, NGK Iridium 10 plugs, 40mm lowered springs, Powerflow 3' stainless steel cat back exhaust ending in a 4' outwardly rolled tailpipe ("Volvo's....... Theyre boxy, but theyre good")
careful stick to the codes its the same looking colour to mine tho it was in the paint shop not that long ago apparently theres 3 shades of it,,some places only list one when my car was painted first time round was completely wrong colour match, had to be rubbed and painted again!paint supplied from different agent
Call Oliver at TMS... give him your registration number.. he puts it in the computer.. and 5 seconds later.. he can tell you what colour your car is. he did that for me when I wanted to know my colour..... all u need is the number plate. job done.. no need to look for ID numbers anywhere....
Johnny5 (Monday 21st September 2009)
Just be careful when looking for the paint. My V70 is Regent red but apparently has a slight difference to the 850!!!
As the T5 came to a lonesome end
Its just the V70 2.5 10 valve SE, pictured here with the 2 people that make life worth living, my babies.
Needs a wash Image taken in the beautiful Malin head, Irelands most northerly point.
