Hi all,
Anybody else had a leak from the oil filler cap and can it be repaired without replacing the cap itself.
My car is a 96 850 t5 auto
Thanks and all the best to you and yours for the new year.
Hi all,
Vovlo dealer can supply a new filler cap seal quite reasonably priced.
These seals are known to go hard, new one will cure the leak.
Easy 10 second job.
Fun in the twisties!
We take the "be polite" rule very seriously!
Yeah it seems quite a common problem and a new filler cap isnt reallly that expensive
I bent (adjusted the two lugs that grip the engine cover) and virtually cured it, but only cause too tight to buy new cap! which would sort it.
Mike
WARNING! Some of the above may be my unbiased opinion, sarcasm, or just total bo****ks.
Thanks to all
i agree, its a 99% chance of it being due to an aged oil cap seal, as these are quite common to go. inexpensive and most likely to be in stock at your local dealer... but don't forget there is also a small chance of there being a breathing problem.
if there is a blocked breather oil pressure can build up, and this can force out oil from seals, usually being the uppermost oil seals first. i recomend changing the cap and seal first, but keep a sneaky eye on it for signs of it coming back. if it does, investigate further ok
FRF FEEDBACK (click here)
(Mon to Fri 9am to 5pm)
