Results 1 to 7 of 7
Thread: auto box filter
    Junior Member
    Sep 2019
    0
    auto box filter
    hi all i have a 2004 s80 d5 goes like the clappers but have a problem with the gear box when hot. i have changed transmission fluid then it ran better for a few days,i wondered if there was a filter and where it is located, any advice welcome. thanks
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Quote Originally Posted by freddyboyj View Post
    There is no filter.
    Sounds like the box may be slipping when hot? if so, it's likely the transmission bands are knackered.
    New gearbox mate or overhaul!!
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Try to get somebody to reset the gearbox software adaptation for a fluid change.
    The daft thing is there is a filter in the gearbox but is got to be totally stripped to pieces to get to it, Definitely not a DIY job.
    correct fluid level when hot ? , As said looking like a rebuild is required.
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Oh yes, gearbox adaption may help (doesn't in most cases and if it does, it lasts about 10 miles).
    Reference the filter.....Hence the rebuild!
  5. #5
    Junior Member
    Sep 2019
    0
    Quote Originally Posted by LeeT5 View Post
    There is no filter.
    Thanks for the speedy reply, will see if i can pick up a replacement box
  6. #6
    Junior Member
    Sep 2019
    0
  7. #7
    Junior Member
    Sep 2019
    0
