Results 1 to 7 of 7
Thread: Exhaust
    Feb 2006
    manchester
    615
    Exhaust
    Can u fit a twin exhaust on a v70 1998 FWD
    Feb 2006
    manchester
    615
    If u can anyone got any pictures
    Trying to keep on top of it
    LeeT5's Avatar
    Oct 2004
    Kent
    955
    AFAIK you can. I know that all the AWD, inc R P1 models had a blanked off section on the drivers side that you just pulled off. You then just needed to get hold of the piece of trim, that finished off the removed section. The later P1 R models (265bhp) already had this section removed and capped off.
    I did this to my P1R that I had. Fabricating the exhaust was the easy part.
    If the FWD cars don't have the section to pull out, then to make it look proffessional and OE, I'd get hold of a rear bumper from an P1 AWD or R and respray it your car's colour. The rest is easy peasy. Definately a great mod!!
    Don't start cutting your bumper as the trim piece won't fit and the mod will look trash.
    2004 V70R 6spd manual:: Custom JRtuning REMAP @ peak 21psi :: Custom 2.75" exhaust :: TTV SMF + 07 Clutch :: WG 5.0 psi :: Tints :: IPD R gauge Rev.3 :: CFWerks door pod :: Forge CBV + yellow spring :: Windowed stock housing + blue filter :: Powerflex :: Superpro Engine mount :: Brembo Dot 5.1 :: TW FMIC :: Eibach 5mm spacers :: Brembo 330mm drilled discs :: iMiV 'Classic'+ BT :: D2R XENARC 5500k + LED H7 + LED H3 :: VolvoTech CFE OBD-V1 :: See garage for full mod list
  4. The Following User Says Thank You to LeeT5 For This Useful Post:
    abdul (Wednesday 27th December 2017)
  5. #4
    Gearbox Killer
    Proving the power of the
    15g....13.4@104.3mph
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,704
    Yep a great mod and on the scale of things is relatively easy, an p1 v70r or awd bumper is the easiest route, with Lee on this one, two tail pipes look better than one in my book and I've been toying with doing this to olive in the near future.
    My Ebay Items http://www.ebay.co.uk/sch/moleadrian...p2047675.l2562
  6. The Following User Says Thank You to MoleT-5R For This Useful Post:
  7. #5
    Feb 2006
    manchester
    615
    Any recommendations on which twin exhaust
  8. #6
    LeeT5's Avatar
    Oct 2004
    Kent
    955
    Quote Originally Posted by abdul View Post
    I'd go custom.
    The BSR is nice but too quiet.
  9. #7
    SpongeBob Foamypants
    Back in my R for the 3rd
    time!!
    foammanmark's Avatar
    Nov 2011
    Nowhere near Blackburn.....
    1,571
    Quote Originally Posted by LeeT5 View Post
    I'd go custom.
    My Son still talks about the noise of the BSR set up on your/my old Laser, which is now Abdul's car.............cos he loved it!!
