Results 1 to 8 of 8
Thread: Gear box
    Feb 2006
    manchester
    613
    Gear box
    Got a grinding noise from front off the car someone says I need a gearbox any suggestions where I can get one it's for a 1999 v70 r awd
    New Identity
    Dangerous Dave's Avatar
    Dec 2006
    West Midlands
    2,360
    Assuming it is drivetrain related - I had a grinding noise on my 850 AWD. Turned out to be the connecting sleeve between the gearbox and the angle gear (part of the AWD system).
    Problem was that the connecting sleeve had worn down the splines on the gearbox so I had to replace it.
    In the later cars I think they 'glued' the connecting sleeve to the gearbox (not sure which year they started that though)
    It could also be the angle gear.
    Anyway, best to get it fully diagnosed before going and getting a gearbox. The sleeve is designed to wear so you don't have to replace more expensive components. A connecting sleeve costs around 90 (last time I checked).
    1996 Olive Green 850 AWD - Forged rods, VXR injectors, 19T, Ostrich 2.0, cold air con. Follow the project here
    1996 Nautic Blue 850 AWD - The daily, resisting the urge to modify
  3. The Following User Says Thank You to Dangerous Dave For This Useful Post:
    abdul (Thursday 30th November 2017)
  4. #3
    SpongeBob Foamypants
    Back in my R for the 3rd
    time!!
    foammanmark's Avatar
    Nov 2011
    Nowhere near Blackburn.....
    1,557
    Hi Abdul, I'm assuming that this is on Laser? Is there not a receipt for a gearbox at 120k miles or so from what I remember? She's only in the 140's now isn't she?
  5. #4
    Feb 2006
    manchester
    613
    Quote Originally Posted by Dangerous Dave View Post
    Will get it checked
  6. #5
    Feb 2006
    manchester
    613
    Quote Originally Posted by foammanmark View Post
    She's on 158 k at the moment I think the gear box was done 8 years ago not sure what the mileage was will check
  7. #6
    Feb 2006
    manchester
    613
    Just looked at the folder the gearbox was done at 99k in 2006
  8. #7
    Feb 2006
    manchester
    613
    As dangerous dave says I am going to look at the awd system before I do anything else
  9. #8
    New Identity
    Dec 2006
    West Midlands
    2,360
    An easy way to check is if the propshaft will turn without turning the front wheels (as the prop is connected directly to the diff). If it does then the rear is disconnected somewhere between the prop and the gearbox output shaft which means the connecting sleeve or the angle gear. You may even be able to get the grinding noise.
