Results 1 to 8 of 8
Thread: Head unit FUBAR
    On a mission
    Tee5alive's Avatar
    Jun 2015
    Hampshire
    294
    Head unit FUBAR
    My HU-803 head unit has a knackered display screen only showing half the info and the rest is all yellow! Also the CD player jumps all the time so I have sourced a perfect second hand one.
    The trouble is the geezer says it needs ‘RECODING’ ??
    Never heard of this before on a Volvo radio, so whats the score if I just swap them out? There is no CODE as such it comes on straight away after disconnecting the battery so what CODE does he mean please?
    http://www.vpcuk.org/forums/image.php?type=sigpic&userid=11614&dateline=143983  7674
    2004 - V70 D5 -'Black Bess' - The new addition
    2002 - C70 T5 'Ragetty Anne' - awaiting rebuild long term storage
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,074
    Most headunits have a 4 digit security code if the power is disconnected for a significant time.
    Not sure if Volvo HU units do. All you can do is plug it in and see. If it then says 'CODE' in the display when you switch it on, then it will need the code.
  3. The Following User Says Thank You to LeeT5 For This Useful Post:
    Tee5alive (Friday 27th October 2017)
  4. #3
    Member
    antonys60r's Avatar
    Jan 2011
    0
    The hu803 has no security code as such but it is programmed to the car it is fitted in. It will need programming to the car by volvo or an Indy with vida software update capability.
  5. The Following 2 Users Say Thank You to antonys60r For This Useful Post:
    LeeT5 (Saturday 9th December 2017),Tee5alive (Friday 27th October 2017)
  6. #4
    Member
    antonys60r's Avatar
    Jan 2011
    0
    Your current hu803 can be repaired. There are a couple of firms online that repair them.
  7. The Following User Says Thank You to antonys60r For This Useful Post:
  8. #5
    On a mission
    Tee5alive's Avatar
    Jun 2015
    Hampshire
    294
    Quote Originally Posted by antonys60r View Post
    REALLY? thats intersting but ill have a big space while its away lol
    Thanks to all!
  9. #6
    Member
    Dec 2017
    5
    So your saying if I was to remove my hu-803 to change the lamps and refit it I'll need someone to program it again. It won't take long to swap the lamps so surely it won't lose its memory that quick right?
    Ryan
    Sent from my iPad using Tapatalk
  10. #7
    On a mission
    Tee5alive's Avatar
    Jun 2015
    Hampshire
    294
    I know I posted this three years ago but I now have another V70 after spending 3 troubled years in a Jaguar! So Im BACK to reliability and a Turbo Brick!
    After removing the existing OEM Head unit and fitting an adaptor plate - Can I just go ahead and fit a 'state of the art' Pioneer GPS/ Bluetooth / USB/ DVD /reversing cam/ kitchen sink and mircowave unit without any problems yes? Sadly a 17 year old Volvo is a bit LACKING in ICE and navigation shall we say!
    I bought a YATOUR ipod adaptor a few years back that was fitted in my estate but if I am ripping out half the dashboard might as well fit a proper head unit yes?
    cheers
  11. #8
    Gearbox Killer
    Proving the power of the
    15g....13.4@104.3mph
    MoleT-5R's Avatar
    Jun 2011
    Mid-Wales
    2,790
    I'd imagine so, this is probably what I should have done on my XC90, but I went down the Grom route due to the MOST system that the audio runs though, which then needs programming by a Stealer to be able to work and in the years I've had her, I've yet to get it to get it done, bit of awaste for money really until I send it in to get the MOST security removed, Not sure if the V70's use the same system, might be worth checking just in case.
