Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Junior Member
    Sep 2016
    5
    Gearbox problem.
    Hi everybody.
    Hope you can all bear with me and maybe give me some good advice.
    I have a D5 v70 which I bought about 3 years ago, in really nice condition and only done 120k.
    The gearbox has been ok mostly all the time Ive had it but late summer it sort of started to play up a bit, clunking into 3rd on the way up but ok when coming down, but recently its started flaring and on a few occasions has missed a gear completely hitting the red line before engaging with a mighty clunk, I suspect valve block but not sure.
    So I would like to keep it because its a lovely car and beautifully made, so how much would it cost to have it stripped and repaired, who would you recommend or do I get rid as its uneconomical to repair.
    Sorry this is a long winded ramble but really nneed some good advice.
    Many thanks
    Alan
    Member
    uqj83l's Avatar
    Jan 2010
    Kent
    2
    You’re looking at around 2500 for a strip and repair I reckon.
    Junior Member
    Sep 2016
    5
    Hi
    Thanks for that, to be honest I thought it would be around that sort of figure.
    I donnt really know what to do, I can get it fixed or p/x it before it fails completely.
    Dec 2015
    Cork, Ireland
    143
    First thing first, what gearbox is that? 5 spd or 6spd?
    Second, I assume the gearbox fluid hasn't been replaced - as Volvo says LifeTime fluid, which is rubbish btw...
    Third - does the car have the latest TCM update?
    Before you start spedning a crazy amount of money for a new gearbox, there are few things to do.
    I would do 3 times drain and fill immediately. Few hundred miles between each drain and fill.
    Use the link to check the Valvoline ATF compatibility of your car.
    http://www.valvolineeurope.com/manag...ricant_advisor
    Alternatively you can use the Mobil ATF or the Toyota ATF.
    Flush might sound a good idea, however at 120k with no fluid replacement can do more harm than good....
    Alternatively if someone does the same in the UK like on the video below, then it would be the best.
    Meantime get the latest TCM software loaded by Volvo.
    SOLD - 2004 Volvo V70R GT/Titanium Gray/Gobi - 103000 Miles, Bilstein B6 Front, Resonator delete, do88 Intake, do88 Lower Intercooler pipe, Forge CBV with green spring, Grey Pierburg TCV, Viva Strut Bar Conversion Kit, 17'Pegasus, 235/45/17 Goodyear Eagle F1 AS3
  5. #5
    Dec 2015
    Cork, Ireland
    143
    Looking at the other topic you opened recently. You have the fluid....
    http://www.vpcuk.org/forums/showthre...63876-Jws-3309
    So does this mean you've already replaced the fluid?
  6. #6
    Junior Member
    Sep 2016
    5
    Hi
    Thanks for your input, sorry I should have put more details.
    Its a 2006 model with the six speed box.
    I have flushed the oil 3 times last summer, final change the oil ran clear red.
    I have been getting it serviced at the local dealer ( Chapmans), I also made sure that they updated any software and checked the fluid level in the gearbox just in case I had not filled it's enough, interestingly they did not �� any transmission problems on the helthcheck,so I think now it may be going down.
    Cheers
    Alan
  7. #7
    Member
    antonys60r's Avatar
    Jan 2011
    0
    Sounds like valve body issues. Early 6 speed autos suffer with this. Worth repairing though.
  8. The Following 2 Users Say Thank You to antonys60r For This Useful Post:
    Alan48 (Monday 16th October 2017),htomi (Monday 16th October 2017)
  9. #8
    Junior Member
    Sep 2016
    5
    Thanks Antony
    I thought it was sticking valves too, happens almost everytime I accelerate hard, but scary on joining motorways.
    Have you any idea of cost to replace / repair valve block?
    Cheers
    Alan
  10. #9
    Member
    antonys60r's Avatar
    Jan 2011
    0
    A new valve body is about 460 plus labour to fit unless you can fit it yourself .
  11. #10
    Trying to keep on top of it
    LeeT5's Avatar
    Oct 2004
    Kent
    993
    Quote Originally Posted by Alan48 View Post
    Hi everybody.
    Many thanks
    Alan
    I have made an enquiry with a good independant Auto transmission specialist on your behalf. He's going to call me back tomorrow with a price to strip and rebuild your gearbox. This guy knows his stuff and has worked on Autos for over 40 years!
    Now I have the info required, 2006 V70 with 6 speed.
    will get back to you tomorrow.
    2004 V70R 6spd manual:: Custom JRtuning REMAP @ peak 21psi :: Custom 2.75" exhaust :: TTV SMF + 07 Clutch :: WG 5.0 psi :: Tints :: IPD R gauge Rev.3 :: CFWerks door pod :: Forge CBV + yellow spring :: Windowed stock housing + blue filter :: Powerflex :: Superpro Engine mount :: Brembo Dot 5.1 :: TW FMIC :: Eibach 5mm spacers :: Brembo 330mm drilled discs :: iMiV 'Classic'+ BT :: D2R XENARC 5500k + LED H7 + LED H3 :: VolvoTech CFE OBD-V1 :: See garage for full mod list
  12. The Following User Says Thank You to LeeT5 For This Useful Post:
  13. #11
    Junior Member
    Sep 2016
    5
    Hi Lee
    Thank you so much for doing that, it really is very kind of you.
    When I get a quote I will have to sit down and work out the economics of its to see if its worth the investment.
    At the end of the day, its not worth a lot even include good working order, but we'll see
    Many thanks
    Alan
  14. #12
    Dec 2015
    Cork, Ireland
    143
    Quote Originally Posted by antonys60r View Post
    Yup, based on the description and the year it is most likely the well known valve body issue.
  15. #13
    Dec 2015
    Cork, Ireland
    143
    Hi Lee
    Many thanks
    Alan
    Id' say if you like the car and besides the gearbox it is in good shape/working order, then fix it. Obviously it depends on the price of the repair.
  16. #14
    LeeT5's Avatar
    Oct 2004
    Kent
    993
    Alan, where abouts in the country are you?
  17. #15
    Junior Member
    Sep 2016
    5
    Hi Lee
    Sorry for delay.
    I'm
    In
    York.
  18. #16
    LeeT5's Avatar
    Oct 2004
    Kent
    993
    Garage has asked for your reg?
  19. #17
    Junior Member
    Sep 2016
    5
    Ov56uef
  20. #18
    Member
    uqj83l's Avatar
    Jan 2010
    Kent
    2
    Here’s a quote I found on a 2005 6sp auto gearbox. Had the valve body replaced, TCM updated, but still never fixed the shift flare.
  21. #19
    LeeT5's Avatar
    Oct 2004
    Kent
    993
    Nice find Bill
    If an auto gearbox starts to do anything that is not considered 'normal', the vehicle should not be driven at all. Most end up with full gearbox rebuilds because owners carry on driving the car.
  22. #20
    LeeT5's Avatar
    Oct 2004
    Kent
    993
    Ov56uef
    I've text the garage the VRN Thursday afternoon.
    I'll give him a tinkle this morning and see what he says.
