Results 1 to 8 of 8
Thread: D5 power loss
    Junior Member
    Jun 2017
    1
    D5 power loss
    Hi all, I have a 2007 S80 D5 185bhp with 88,000 miles on the clock, it just started losing power about a week ago, intermittently. I have changed the fuel filter with no difference. Turbo pipes seem okay, but found a plastic linkage disconnected front left side of engine , come from a stepper motor of some sort and goes to a link on the cylinder head. Reconnected it but doesn't seem to have made any immediate difference . Any thoughts or suggestions??
    The daRk knight
    LeeT5's Avatar
    Oct 2004
    Kent
    942
    Were gonna need more information.
    1. Manual or auto?
    2. Have you plugged in diagnostics and were there any fault codes, if so, what were they?
    3. A picture of the part that was disconnected may help!
    2004 V70R 6spd manual:: Custom JRtuning REMAP @ peak 21psi :: Custom 2.75" exhaust :: TTV SMF + 07 Clutch :: WG 5.0 psi :: Tints :: IPD R gauge Rev.3 :: CFWerks door pod :: Forge CBV + yellow spring :: Windowed stock housing + blue filter :: Powerflex :: Superpro Engine mount :: Brembo Dot 5.1 :: TW FMIC :: Eibach 5mm spacers :: Brembo 330mm drilled discs :: iMiV 'Classic'+ BT :: D2R XENARC 5500k + LED H7 + LED H3 :: VolvoTech CFE OBD-V1 :: See garage for full mod list
    Junior Member
    Jun 2017
    1
    Its an auto box, diagnostics didn't come up with any engine related codes? for some reason the site isn't letting me upload pictures. If I start the car and it has no power, just stopping for a few minutes and then starting again sometimes gets rid of it (sometimes not!) yesterday it was running perfect, stopped for literally a minute then when started again it was like in some sort of limp mode?
    The daRk knight
    LeeT5's Avatar
    Oct 2004
    Kent
    942
    What diagnostics you using?
    If it's cheap, it won't always pick up fault codes. There will definitely be a code if it's loss of power and intermittent.
    Sounds like you have a boost leak. First place I'd look is the IC. They commonly crack on the sides.
  5. #5
    Swollen Member
    stephenevans99's Avatar
    May 2006
    1,467
    Sounds like the linkage is the Swirl Pot Actuator Arm....common failure on the EU4 D5
  6. #6
    Junior Member
    Jun 2017
    1
    Just took off the MAF sensor today and cleaned it, the fault has been on constantly for three days, gearchange all over the place and as much power as an old diesel escort!!! having cleaned the sensor with carb cleaner and put it back on, its now running like a scalded cat!! fingers crossed that is it (not convinced I have to say) time will tell, apparently a new one is 400???
  7. #7
    The daRk knight
    LeeT5's Avatar
    Oct 2004
    Kent
    942
    Quote Originally Posted by andycoop62 View Post
    More like 300 inc vat from dealer.
    You can get a Bosch sensor for much less on ebay. I bought one from Poland, boxed and sealed as new for around 89 delivered.
  8. #8
    Swollen Member
    May 2006
    1,467
    Cleaning the MAF with carb cleaner probably isn't the best idea tbh....many have done it for years without issues but you're best using electrical contact cleaner.
    Good job on fixing your issue
  9. The Following 2 Users Say Thank You to stephenevans99 For This Useful Post:
    andycoop62 (Friday 23rd June 2017),nosh (Thursday 6th July 2017)
