Results 1 to 15 of 15
    Junior Member
    Aug 2016
    1
    volvo 240 gl v8 project
Size:  60.3 KBName:  JAG ENGINE.jpg
    Hi all
    Had this a while now and thought i had better get on it
    the unfortunate jaguar 2002 4.0 sc xjr 308 cane along mechanically sound but tin worm had had a busy time on the body, and was deemed uneconomical to repair
    quite a lively old bus 370 bhp 380lb ft toque with a merc 5 speed box.
    as a friend of mine had offered me the volvo in a deal with some other stuff, got to thinking a quick look at the engine bay monstrous space that v8 jag would look good in there me thinks! 2 painstaking weeks stripping the jag and thinning the loom to a minimum so it can still run engine and gearbox still a big box of wiring tho, got the engine and gear box fitted fabricated mounts, using a 940 turbo prop fits both ends just need shortening 40 mm
    wondered if any one else on here has fitted a jag engine as they are available in all shapes and sizes for not very much
    any input or ideas greatly appreciated
  2. The Following 4 Users Say Thank You to jimperry For This Useful Post:
    petrolh34d (Tuesday 30th May 2017),stribo (Sunday 4th June 2017),t5 pete (Monday 29th May 2017),Tomcat (Tuesday 30th May 2017)
  3. #2
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,362
    Can't answer your question, but I'm very much looking forward to updates on this one.
    PIC][/SIGPIC]
    aaaaaaaaaaaaaaaaaaaaaaaaa
  4. #3
    Junior Member
    Aug 2016
    1
Size:  1.17 MBName:  DSC_0041.JPG
Size:  452.8 KBName:  DSC_0048.JPG
    Hi few more pics off to get prop shortened tomorrow will also get a 16 toothed wheel just behind the front joint this is needed for gear box ecu to know road speed the jag has 3.06 diff 48 tooth abs pick up divided by 3 ish. road speed taken from back wheels (3 turns of prop to 1 of road wheel) the gearbox ecu knows the in and out shaft speed and compares it to the road speed if it don't like what it sees it defaults to limp mode this could be the hardest bit to get right
  5. #4
    All the ladies love it
    sideways!
    Doingitsideways's Avatar
    Nov 2012
    Manchester
    2,186
    Ooohh... I do love a dirty V8.
    Keep the updates coming, not forgetting the obligatory start up vid with half an exhaust
  6. The Following User Says Thank You to Doingitsideways For This Useful Post:
  7. #5
    Junior Member
    Aug 2016
    1
    i still love my old 850r estate sweet 5 potName:  pioneer 329.JPG
  8. The Following User Says Thank You to jimperry For This Useful Post:
    Doingitsideways (Monday 29th May 2017)
  9. #6
    Junior Member
    Aug 2016
    1
    just realized that was 2012 time flys
  10. #7
    Sick Brick
    petrolh34d's Avatar
    Jan 2015
    Ireland
    89
    Looking forward to this
    Silver - 1999 Volvo V70 - 2.5 TDi - Miles: 200,000
    Scrapped: Silver - 1998 Volvo V70 - 2.5 TDi - Miles: 300,000+
  11. #8
    Trader
    Tomcat's Avatar
    Aug 2004
    Sadly still stuck in Wigan
    2,965
    Ooof!!! Nice project!! looking forward to updates!!
    Previous cars:
  12. #9
    Junior Member
    Aug 2016
    1
    Hi thanks for the encouragement, stripped the interior today the dash has a lot of bits hahaName:  DSC_0070.JPG
    connected all the v8 wiring loom together for a compareName:  DSC_0083.JPG
    the good thing is the bulkhead has a huge plate that can be removed makes life a bit easier,removed the volvo wiring loom as well
    the old bullet fuse box has seen better days i might remake a simplified one with the basics.
    dont know what state a 1988 volvo is usually like rot wise this one seems quiet good apart from a 2 inch hole under the rear seat and same in inner rear wheel arch the other issues are fuel tank it dont fit in the boot, it is a twin immersed pump type i may cut the top out and make small a swirl pot tank with the pumps inside fed from the old tank ecu gets upset if different pumps are used as they are pwm type ,and the radiator is to tall i have a 850 r one so i may try to fit thatName:  DSC_0079.JPG
Size:  1.15 MB any other ideas for a radiator type would be appreciated cheers jim
  13. #10
    Junior Member
    Aug 2016
    1
Size:  1.06 MBName:  DSC_0075.JPG
  14. The Following User Says Thank You to jimperry For This Useful Post:
    petrolh34d (Friday 2nd June 2017)
  15. #11
    Junior Member
    Aug 2016
    1
    HI
    looks lice a 850r rad will do the job will use the jag twin fansName:  DSC_0069.JPG
    had a bit of a chopping spree on gear box tunnel lowered the gear lever mount 60mm to accommodate the taller larger shifter assyName:  DSC_0084.JPG
Size:  928.0 KB[ATTACH=CON FIG]31612[/ATTACH]
    thats all i managed today as the argon gas ran out and the weather has now taken a turn for the worse
    cheers jim
    Attached Images Attached Images
  16. The Following 5 Users Say Thank You to jimperry For This Useful Post:
    Dangerous Dave (Friday 2nd June 2017),Doingitsideways (Friday 2nd June 2017),martin_r_smith (Friday 2nd June 2017),Ric@rdo (Saturday 3rd June 2017),stribo (Sunday 4th June 2017)
  17. #12
    Junior Member
    Aug 2016
    1
    VID 20170911 WA0003
    first start a way to go as yet
  18. #13
    Whiny Old Git
    Aching bones :(
    claymore's Avatar
    Aug 2009
    Shrewsbury
    4,362
    Quote Originally Posted by jimperry View Post
    VID 20170911 WA0003
    Try this:
    PIC][/SIGPIC]
  19. The Following 4 Users Say Thank You to claymore For This Useful Post:
    Jamest5r (Thursday 14th September 2017),jimperry (Saturday 16th September 2017),MoleT-5R (Thursday 14th September 2017),Ric@rdo (Thursday 14th September 2017)
  20. #14
    Aug 2008
    Lockerbie, SW Scotland
    2
    MMMMmmmm........ v8 sound. Nice!!!
    08' V50 D5 R Design
    09' V70 2.0D R Design
    My investment: - 96' 850R estate manual
  21. #15
    Junior Member
    Aug 2016
    1
    Thanks for that Claymore
    Have been busy lately and have not had time to do much a quick update
    the main problem i had was a gear box ratio fault due to the diff ratio the jag was a 3.06 and the volvo i believe is a 4.27
    the internal speedo pickup on the diff is 48 tooth same as the jag abs rings due to axle ratio the difference is to much and the gear box ecu assumes there is clutch slipping internally and fail safe is set, so i figured 48 divided by 3 roughly 16 teeth on prop should do it, set about the diff flange with a file and grinderName:  IMG-20170912-WA0001.jpeg
Size:  715.7 KB added a 850 rear abs sensor on a small bracket it seems happy and gearbox works ok think i will have to find a 3.6 diff or there abouts at a later date ,Name:  DSC_0007_9.JPG
Size:  602.7 KBName:  DSC_0008_6.JPG
Size:  688.1 KBalso added a small fuel secondary tank to house the twin jag pumps
  22. The Following 3 Users Say Thank You to jimperry For This Useful Post:
    barkster1971 (Friday 22nd September 2017),claymore (Sunday 17th September 2017),kmb (Sunday 17th September 2017)
