Results 1 to 6 of 6
Thread: 940 cutting out
    May 2013
    22
    940 cutting out
    Got a problem with my 940, it's a b230fk with a 16/19 turbo. Issue is when your slowing down the revs start dieing and it cuts out unless you build the revs up, seems to do it mainly when it gets up to temperature or after you give it abit of stick then slow down. I've tryed a different icv (used but was good on my last 940 and was ultrasonic cleaned) but that doesn't mean it's still good? Anyone got any ideas? I'm really fed up with this thing now, I've done a lot of work on this car and it all seems to be for nothing
    Cheers guys
    Feb 2012
    135
    Quote Originally Posted by wiganer31 View Post
    Cheers guys
    Had this on my 1991 Wentworth 940 2litre turbo.......it was quite dangerous sometimes coming up to a roundabout in the town to beat others around and it would cut right out in front of them.
    I had no error codes at all and eventually i had a new engine put in at Taunton Volvo as the piston skirts are shorter on this model and the pistons slap i think they cured it by different pistons and the oil supply jets in the block for extra cooling on later models?
    While getting this done i asked them to check the cutting out but when i picked it up it still did it and did it forever more, just had to be careful around minimum throttle not to suddenly get to idle mode but gently.
    Mercedes C320CDI Sport Estate 3 litre V6 7 Gear Auto
    Remap 290bhp 628Nm torque @ 1600revs 45.1mpg
    May 2013
    22
    I'm looking for another 940 to break for the engine and box so I can take my current engine out and rip it apart
    If in doubt thrash it and see
    what happens
    woz's Avatar
    Mar 2005
    Bristol BS5
    58
    mate, its not likely to be a roblem in the engine - like the other poster said they had a new engine and made nota jot of difference. It will be a fuelling prolem - possibly and air leak. So get another car to break but swap over the hoses, throttle butterfly, sensors, EGR whatever but save the engine until AFTER you have fixed the problem.
    W
  5. #5
    what happens
    woz's Avatar
    Mar 2005
    Bristol BS5
    58
    got it sorted yet buddy?
  6. #6
    Trying to keep on top of it
    LeeT5's Avatar
    Oct 2004
    Kent
    1,040
    9 times out of 10, poor idle/stalling when engine hot is normally down to contaminated throttle body. The build up of black carbon gets sticky when hot and causes a lack of air flow when off throttle, causing the engine to stall.
    Just remove the induction hoses and degunge the throttle assy using proper throttle cleaner and a lint free cloth. It will make a huge difference!
    It may also be worth removing and cleaning the MAP sensor, Boost pressure sensor and Air flow meter a clean too! All will make big differences to driveability, including better throttle response, better MPG, more boost and just nicer to drive, smoother.
    2004 V70R 6spd manual:: Custom JRtuning REMAP @ peak 21psi :: Custom 2.75" exhaust :: TTV SMF + 07 Clutch :: WG 5.0 psi :: Tints :: IPD R gauge Rev.3 :: CFWerks door pod :: Forge CBV + yellow spring :: Windowed stock housing + blue filter :: Powerflex :: Superpro Engine mount :: Brembo Dot 5.1 :: TW FMIC :: Eibach 5mm spacers :: Brembo 330mm drilled discs :: iMiV 'Classic'+ BT :: D2R XENARC 5500k + LED H7 + LED H3 :: VolvoTech CFE OBD-V1 :: See garage for full mod list
