anyone please.
i need to exchange the Throttle Position Sensor thingy n my V70.
anybody can point out where and what I am looking for please?
Picture would be great if possible.
its a 3.2001 V70 Automatic 2.4
Thank you
anyone please.
Thank you
It's the ETM on the passenger side of the inlet manifold, you will need a new gasket and it would be wise to have Vida.
thanks. ill have access to a garage computer. should be ok
If after changing it the car starts, stalls several times and then won't restart at all with that unit it will have the wrong software.
erh. whats happens then ? how do i get the right unit then ? not spending money on volvo garage. if this gets into loads to finance volvo employees the car will get scrapped. sorry but i never go to the big market places.
i have a garage which the standard garage computer, reset service codes blah blah blah but i don't know what this thing can do and if it can do what i need.
but i defo not going to volvo.
they charging an arm and a leg just for looking at it and then try to sell some little eco potholes ££££ filler.
sorry for the rant but just the idea gives me anger.
i sourced the Part for affordable 27£. volvo said some about 146 which is ridiculous .
Ok. do i have this actually right.
my mechanic said to buy a Throttle Positioning sensor which i ordered.
the computer reading saying
Air Flow Faulty flow ( which is Mass Sensor but i don't care of Emission )
Accelerator Pedal (AP) poistioning sensor faulty signal
Throttle Position ( TP ) Mailfunction
Communication with Throttle Unit Faulty Signal
if this is something else, as what i ordered?
i never been without derivable Car in 35 Years and not intend having it but not able to drive as i need to keep the Galaxy then.
This V70 should be derivable on the Road by Saturday as someone want to collect the Galaxy.
cant do it in this case as I am not a Bus passenger.
is this a easy fix ?
I don't fully understand what you're saying. The ETM I mentioned is the Electronic Throttle Module, the same part as you listed in your last post (Throttle Unit).
With the description you posted the ETM is the most likely cause, then the accelerator pedal.
sorry if i confuse people now.
the reading on the garage computer was showing
i been told by the mechanic get a throttle positioning sensor which i ordered but this is a black module block and it seems it is the one as i asked where it is.
the symptoms on the car
the engine management light was on in yellow.
the car would not start once driven in a while unless disconnecting the battery for a moment and reconnect.
it would start and drive fine.
now i don't know what it actually is. because it seems this pedal sensor - if this is what i need is not to buy unless going to volvo which i try to avoid for money reasons.
but i need a car ready by Saturday as I need a Car running as fresh Air. sorry never been without a car for even one Day in over 30 years.
If i cant get the Part i need in time to get it fixed by Saturday i cant sell the Galaxy so one needs to be scrapped.
right update so far.
i been and seen some friends with garages. no one can help as lack of original volvo data.
but i have one who said he can do more then the standard garage computers.
it looks different to.
at least he did not refer me to a replacement etm and volvo to throw my money in a bin and listen to there story's to make more money.
apparently he can reset and program on the volvo and other stuff to influence .
not sure but think is worth giving a try instead giving volvo my money.
i also was told to clean the ETM which i did. using carb cleaner
it was quiet black inside, now is clean and silver again.
put it back in started and it started straight away.
switched of, started again waited to get warm, was a bit ruff at first like missfiring.
after 15 min and 8 start sequences which worked on the dot it started to calm down and run on 1000 rpm instead 1100 tp 1200 like the first two times i started the car.
still not sure if it helped and the engine system service required is still on the board computer. hopefully my friend with the big black computer is able to help now.
the engine management light is off now. so i see this as progress.
i did not change anything because the throttle position sensor i ordered came today and don't know what it is but i cant see anything like that anywhere so its going back.
would, just in case, someone have a working etm for a 2001 v70 as spare ?
otherwise anybody with some suggestion which may help ?
Thank you
I've seen a few dodgy/dirty maf sensors throw throttle position sensor faults (me7 quirk I guess)
310.2bhp / 333ft/lb
SOLD
Got an old discovery now.
A faulty or dirty maf isn't just an emissions problem, it can totally screw the engine management into giving most of the symptoms listed above.
310.2bhp / 333ft/lb
SOLD
Maybe some help to identify what is at fault
http://xemodex.com/us/pdf/ETM%20Flow...-new-final.pdf
Hi M-R-P.
i exchanged the MAF sensor after i tried to clean it first i seen on ebay one brandnew sold just around the corner. £ 23 - so yes - affordable acceptable price
fetched it installed it no codes came up.
started the car and ran ruff again. disconnected the battery for a moment started it again.
missfire sound for 1 to 2 minutes then 1000 revs. but still sound like missfire bewteen.
so Maf Sensor replaced. i got a Throttle Positioning Sensor which came today but nothing on the Throttle Body looks similar, so dont know what they send me and for what car it is. even ordered for mine.
ripping my hairs out here.
tried everything even told them so called volvo mechanics online to stuff there volvo crap telling me go to volvo.
sorry but i don't see the point paying for a 15 year old car loads of money especially to volvo as this fault is created by them apparently.
last chance i seen if nothing else works hoping this guy who told me he can remap volvos and all other things he can reprogram something or even a used Throttle body for me to put in for cheap.
Firstly, you need to calm down and stop ranting on about other stuff that is not relevant....it's bad enough, us English people trying to make sense of what you're saying, without you keep going off in a tangent talking about being a bus passenger, Eco potholes or the local Market!! None of which makes any sense.
We all get that you're probably Polish or Czech??? Anyway, that's irrelevant.....the main thing is we ALL here to help, but you're not listening mate!
Our very own Volvo Guru, who splits himself between two main Volvo forums and leads an extremely busy life, has already given you wise guidance and advice. Clearly, you and your mechanic put together don't really understand what's happening to your car and you cannot interpret the codes properly.
The above codes, highlighted RED, indicate an internal fault in the ETM (Electronic Throttle Module). This is where Tim told you it was....."bolted to the side of the inlet manifold". If you and your mechanic don't understand that or your mechanic doesn't understand what a 'Throttle Module' is or doesn't recognise it, then the best thing you can do is shut the bonnet and drive/limp/recover the car to Volvo main dealer.
Secondly, to ignore the highlighted fault in BLACK is foolish! The car will never run correctly if this is faulty, dirty or not working as it should, and whilst it will affect your emissions, it will also affect your wallet and cost you more money in fuel, spark plugs fouling and other problems later on associated with incorrect fueling and air metering.
As Tim already told you....if you've ordered an ETM and it doesn't have the correct software loaded, the car will not run. This is why your more likely to require main dealer help on this occasion, as they have the facility to not only fix your car but they also have the facility to load the software correctly and reset adaptations to allow the ECM to relearn the new ETM and the car will then run smoothly etc.
If you cannot reset adaptations then you are wasting your time. (This is why you need VIDA/DICE) or a Diagnostic tool capable of resetting adaptations.
Does any of what I've said, make any sense to you or your mechanic?? If not, then we are all wasting our time and my only advice to you is to leave the car well alone before you do any more damage or waste any more of your money.
ˆˆ + 1
SOLD - 2004 Volvo V70R GT/Titanium Gray/Gobi - 103000 Miles, Bilstein B6 Front, Resonator delete, do88 Intake, do88 Lower Intercooler pipe, Forge CBV with green spring, Grey Pierburg TCV, Viva Strut Bar Conversion Kit, 17'Pegasus, 235/45/17 Goodyear Eagle F1 AS3
First yes i am German. sorry but i cant change that.
second i understand the part of not ranting but i am fed up seeing loads of pounds spending to a volvo dealer as they only try to make £££ out of any old car because i don't buy a new one.
because i been on a Dealer and been told is more Emission Friendly buying a newer Model and theirs fully checked. what an answer about getting my Car running.
third yes i replaced the Mass Sensor yesterday
even i find Cat and other low emission things far over rated and only costing money.
i try not to go to volvo dealer themselves as i didn't buy a BMW for this reason ( BMW only ).
i try to get this damn ETM somehow fixed or working without getting £££ loss Volvo Dealers involved.
Sorry but the Car needed to be cheap otherwise i would go for a 3 Year old Van which i cant afford but i need Space. and the MOT History was good including Loads of Services up to 2015.
Finance Options are not my thing, i buy a Car i owe the Car not a Finance Company.
i hope i explained my situation.
Volvos aren't cheap either (compared to the famous German brands) when it comes to maintenance or service.
I suspect the check engine light was ON when you purchased the car correct?
This should have been a sing for you to either stay away or inspect the car properly with a mechanic who knows Volvos inside-out and able to assess what's required to repair it.
Service stamps are one thing, reality is another. Sometimes these two are far away from each other...
In addition to Lee's comments above, several parts would require software to be loaded by a Volvo Dealer or by a specialist who has official subscription to Volvo. The ETM is one of these. Neither of these will be cheap.
To help: you may want to connect to Lukas @ http://volvodiagnostic.com/contact/, he might be able to fix the ETM module.
I understand your misdirected anger now, as a common courtesy please direct it where it originated from and then you could give feedback on the results. The anger is of no help but the feedback could be a positive contribution to the forum.
Your location shows as less than 30 miles from me, if you can safely drive the car I could spare a few minutes one day next week to have a look at it. If it is the ETM then I would just advise BBA Reman or a new unit from Volvo.
