Started doing this today, I do have a ETM problem but it's very intermittent never continuous. But this happened today
jamesy12345 (Sunday 27th November 2016),MaxiSNK (Sunday 27th November 2016)
ETM = Electronic Throttle Module.
You might have a DIM (Drivers Information Module) fault
You have the old type DIM as you don't have the chrome rings around the dials. A replacement DIM will have Chrome rings and looks the nuts. It also has LED illumination, rather than incandescent bulbs.
Not cheap I'm afraid either.
You'll need to read codes, note them, clear them and report back.
When it does it again, or any other weird fault on the display, re read the codes and that will confirm the issue and whether it is indeed your DIM.
