Or just pull the fuse for the headlight wipers in the meantime.
2001 V70 T5 (Manual) - The Turnip
1999 9-5 Aero (Manual) - Sven
stricky1967 (Tuesday 25th October 2016)
Well wasn't looking forward to this job (again) but replaced all the coil springs with volvo OEM today. The car feels amazing now, like night and day, many thanks to Lee for the advise given, even had the ole girl in comfort for the first time in donkeys. Looking forward to completing the suspension refresh after noting this difference.
interestingly made in the UK
2003 V70R Titanium/Atacama
LeeT5 (Sunday 30th October 2016)
Well done! Keep going
SOLD - 2004 Volvo V70R GT/Titanium Gray/Gobi - 103000 Miles, Bilstein B6 Front, Resonator delete, do88 Intake, do88 Lower Intercooler pipe, Forge CBV with green spring, Grey Pierburg TCV, Viva Strut Bar Conversion Kit, 17'Pegasus, 235/45/17 Goodyear Eagle F1 AS3
stricky1967 (Thursday 27th October 2016)
Got a misfire code in VIDA, so did the plugs and coil packs the other day. OE plugs and Bosch 0221604010 coil packs, all is well again.
LeeT5 (Saturday 11th February 2017)
Down to Tim Williams getting the ole' block treatment and an expensive PCV rubber pipe or two fitted, awesome bloke.
Liner shim, pcv and timing belt all in one jobbie?
Saves a few quid having it all done at once.
310.2bhp / 333ft/lb
SOLD
Got an old discovery now.
stricky1967 (Saturday 5th November 2016)
Happy days to knock those jobs off the list , it's a lot of work for 1 day , Great service you can see why people travel so far to Tim to do his stuff ..
He also did the angle gear/driveshaft seals too, seemed to think it may be where my angle gear leak was from, he did a lot in one long day, it was amazing to watch him, almost think he could do it all blindfolded.
Think he said he would have finished the job two hours quicker if it wasn't for me asking question and distracting him..... lol
Wish he was a bit closer, I dont think I'd touch my car if he was, I have total confidence in him.
I'll be getting mine done soon, Shimmed block, timing belt kit and WP. PCV is good as I only replaced that 20k ago.
Will be a good opportunity to finally sort out those pesky exhaust manifold head studs that keep coming loose.
He did my water pump too as I'd got a new one, but said it didn't need it, the old one it was in perfect working order @115k , couldn't feel any play in it.
The PCV looked OK, the hole in the front of the block was "clean as a whistle" he said. But better to change out though.
Thankfully, the block was in good shape, but showed a little distortion between cyl1 and cyl2 as the shim didn't tap in as easily as the rest.
Exhaust manifold was blowing on 4 cylinders
I shimmed the sonic 3yrs back, waterpump and belts as well. I'll do the s60r once things die down with the other Volvo's
Well I'm glad that job is done, wasn't easy
Well done
stricky1967 (Tuesday 31st January 2017)
the old one, fair amount of play in it, may send it off to my mate in Sweden to get rebuilt and if possible improved upon.
On to the next job, Ferrita downpipe and system
Harvey (Tuesday 31st January 2017)
I'm looking forward to seeing it fitted.
me too got the downpipe on this morning but unfortuantly didnt realise that I had the wrong nuts supplied from volvo, I have the older studs in the turbine flange with m8 lock nuts but, also didnt get a new o2 sensor as the front one seems easy enough to swap out, my wallet is hoping the old one lasts a few more miles yet
Is that a Mini Cooper in the background?
