Hi all
Just bought a used goost bauge off the bay, alleged to be from a scooby but no markings to confirm that.
Problem is, it reads just over 2psi with nothing connected, and I can suck it down to ~5 on the vacuum side but can blow it up to only about 3psi.
Is this normal ? A mark on the dial suggests someone has already been inside it, but I can't get it apart myself.
If / when I have one worth fitting, is the arrowed joint the right place to which to connect it ?
