If I run with the air con on no problem fan cuts in
If I run with the air con off sometimes the fan cuts in but other times not
I have rigged a live direct from the battery
I have replaced the Relay
I have replaced the thermostat and the temp sensor
I have noticed though that on start the REC and Air Con Lights flash for about 15 seconds
Is this a problem?
Air con works fine
