Hello
I have a standard 7 way bypass module to drive trailer lights via a 12N connector. Similar to what is described here: http://www.towsure.com/fit_a_multiplex_bypass_relay
I understand I need an in-line fused connection to power the unit, and need tap into the each appropriate light wire.
Where would be the ideal place to:
* get the power connection. There is a fuse box in the boot behind the LHS trim door. Is there an easy way to get at the supply there?
* where I should tap into the separate light feeds.
If anyone has done this before would welcome some tips.
Cheers
Chris
