Results 1 to 10 of 10
    Gold 'N' Brown's Avatar
    May 2013
    Edinburgh
    15
    Cambelt replacement quote
    Does anyone know what the guide time is, that a garage would estimate the job by, for replacing the belt, tensioners and pump on a T5? In my case a Ph2 2.3 V70.
    What would you expect to pay at an Indy for the labour only?
    My usual garage have quoted £150 labour only. They aren't a Volvo indy but they are an absolutely brilliant old school family business that I've used for a few years. Just curious as to whether they are quoting roughly the right sort of ball-park figure (obviously depends on hourly rate I know).
    2001 V70 T5 (Manual) - The Turnip
    1999 9-5 Aero (Manual) - Sven
    Keeping it looking stock
    Harvey's Avatar
    Mar 2012
    Newton abbot, Devon
    920
    Parts are around £85 from volvo.
    Last garage that did it for me charged 1.5 hr time to do it without water pump.
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    Cost me 190 all-in a few years ago but I didn't have the pump changed.
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
    Wierdly beardly
    Jul 2009
    Doncaster, Yorkshire - but still Welsh
    275
    Belt only is pretty straight forward, its the pump that is the PITA. Access to it is a pig and to prevent leaks you need to clean the mating face scrupulously. IIRC it took me a (long) half day to do my last one - a P1 V70R AWD. I image the P2 will be very similar, so if your indy is charging say £40-50/hr then it sounds reasonable IMHO.
    Currently - '96 850R auto
    Previously - '97 S70 T5 manual, '98 V70R AWD auto, '98 V70R Auto in Nautic Blue Mica with LPG (went to Germany!), 1996 850R Auto, lots of various 940s, 960s and a crappy 850 2.0
  5. #5
    May 2013
    Edinburgh
    15
    Ah, that's interesting about the pump as I didn't know it was a sod to do. Assumed it would only be another 10 minutes to swap that out.
  6. #6
    Dec 2015
    Cork, Ireland
    143
    As an advice, same time go for the wpump replacement too. Better to be safe than sorry.
    I would say, 2 hrs in total with the wpump together for a good mechanic.
    SOLD - 2004 Volvo V70R GT/Titanium Gray/Gobi - 103000 Miles, Bilstein B6 Front, Resonator delete, do88 Intake, do88 Lower Intercooler pipe, Forge CBV with green spring, Grey Pierburg TCV, Viva Strut Bar Conversion Kit, 17'Pegasus, 235/45/17 Goodyear Eagle F1 AS3
  7. #7
    Trader
    Aug 2005
    coalville
    68
    1.2-1.3 hours is enough time to do just a cam belt kit on your car. I would only change the water pump if it needs doing as most of the original ones outlast the engines, most cheap pumps last up to 2 years. If having a water pump at the same time it should add no more that 0.6 hrs at the very most NOT the full time to change a pump from scratch.
  8. #8
    Dec 2015
    Cork, Ireland
    143
    Yeah, noticed the same, ex the original wpump lasts very long opposite to the replacement one. I got the replacement pump from Volvo and lasted only for 75k miles vs the orig one which was taken out at 100k miles.
  9. #9
    Trader
    Kingsford G's Avatar
    Nov 2011
    Colchester,Essex
    1,352
    Id charge 2 hours max which is 80 quid.
  10. #10
    May 2013
    Edinburgh
    15
    Had the work done. Charged £161 for the full job inc water pump, plus doing the aux belt tensioner too (EDIT: that's labour only. I got a Gates Powergrip kit from eBay for about £80). A few quid of that was for Anti Freeze, though I've no idea why they needed to drop any out for the job, unless they completely disconnected the reservoir to get it out of the way.
    On the plus side, engine seems a bit more peppy, sort of less laggy at low rpm, though maybe that's a placebo. Early indications are possible slight improvement in MPG (to the order of maybe 5%). So I wonder if the timing was slightly off before.
    On the downside, it hasn't cured the rough bearing type noise I've had for a while.
